Advise: BEst cam for nitrous.
Old Sep 8, 2003 | 04:29 AM
lowdowndirty's Avatar
lowdowndirty
Default Advise: Best cam for nitrous.
Tried the search but I don't have an LT4. :lol:
So....this winter a new cam will be coming and I will probably run the stock LS1 heads as this seems to be the trend (big numbers w/ stock heads). Also, I want to run a mild shot of nitrous (100 shot). From what I understand, I need a wide lobe sep. angle (112-114) and higher liht/longer duration on the exhaust.
I have an M6 and probably won't change gears unless the clutch goes bye-bye soon. Maybe someone can just push me in the right direction. I would have posted in the "other" section, but there seems to be a better response over here. Thanks in advance. Chris
[Modified by lowdowndirty, 9:46 AM 9/8/2003]
Old Sep 8, 2003 | 08:42 PM
lowdowndirty
Default Re: Advise: Best cam for nitrous. (lowdowndirty)
Come on guys........I know what's involved (all the parts, labor, yadda, yadda, yadda) I just need some recommendations or some real world experience w/ certain vendors. Thanks
Old Sep 8, 2003 | 08:46 PM
402Sam's Avatar
402Sam
Well you always want the exhaust # to be higher then the intake #. Like the cam I am getting from texas-speed.com. Specs on it are 231/237 .598/.595 112LSA
Old Sep 8, 2003 | 08:52 PM
lowdowndirty
Default Re: Advise: Best cam for nitrous. (sprayedc5)
That's pretty large. With that type of duration, it should have a nice lope too.
Thank you
Old Sep 8, 2003 | 09:04 PM
Dugmole's Avatar
Dugmole
St. Jude Donor '12-'13-'14-'15-'16
Hey Chris.. I am with you. I have heard that the G5X2 would be a good nitrous cam. Anybody out there with this cam and or H/C package with a dyno they can post? G5X2 spec's 232/240 595/608 112.
Old Sep 8, 2003 | 09:11 PM
lowdowndirty
Default Re: Advise: Best cam for nitrous. (Dugmole)
I don't think I want that much lift (over .600") w/ stock heads....right????
Old Sep 8, 2003 | 09:16 PM
Dugmole's Avatar
Dugmole
I don't think that stock heads are the problem. You would need springs, retainers and pushrods.
Old Sep 8, 2003 | 09:21 PM
SvenOdin's Avatar
SvenOdin
I have the G5X2 cam, but not running the juice. I asked Lou, and he said that the cam would be fantastic with nitrous applications.
This cam will work with stock heads. In fact, there are several members running this cam with their stock heads and some bolt-ons making some very impressive power :yesnod:
Old Sep 8, 2003 | 09:22 PM
lowdowndirty
Right on, thank you. :thumbs:
[Modified by lowdowndirty, 2:23 AM 9/9/2003]
Old Sep 10, 2003 | 01:46 AM
lowdowndirty
Anyone running this cam w/ stock heads (ported or unported) and nitrous? :thumbs:
To Advise: BEst cam for nitrous.
