Kumho tires
Old Sep 8, 2003 | 11:25 AM
torose's Avatar
torose
Default Kumho tires
Just put on a set of Kumho Ecsta MX on 2000 Vert and feels like this tire has a higher profile than stock Goodyears as the car seems to sit about 1 in higher. Tire sizes are stock (245/45-17 in front, 275/40-18 in rear). Curious if other people with Kumhos had similar opinion?
Also, tire installer recommended running 35 psi (cold) to get better wear. Is he correct?
Old Sep 8, 2003 | 12:36 PM
bgood's Avatar
bgood
Cruise-In IV Veteran
St. Jude Contributor
Default Re: Kumho tires (torose)
Your ride height will probably feel higher since you are going from tires with little tread to new tires with full tread. The new tire heights are the same as the old tire heights. (25.7" front and 26.7" rear)
I found that running 35psi on the rears for street driving gives that best traction and wear. I've tried everything from 28psi to 35psi. Do a search and there are a few threads discussing the tire pressure for the MX's.
Old Sep 8, 2003 | 02:10 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
I have been running 34 PSI because I noticed the tires turn in a little 'sharper' there than at 30 PSI. At about 4000 miles, they are wearing perfectly normal.
Old Sep 8, 2003 | 02:40 PM
Traffic Hater's Avatar
Traffic Hater
Default Re: Kumho tires (bgood)
:iagree:
To Kumho tires
