DTC code causing check engine light
Old Sep 8, 2003 | 07:00 PM
spiffo's Avatar
spiffo
2nd Gear
Default DTC code causing check engine light
Twice in the last week I've had a DTC code trigger the check engine light. I'm getting:
P0332 Knock Sensor (KS) 2 Circuit Failure
Is this the knock sensor itself failing or the circuit wiring? Will replacing the knock sensor(s) take care of this?
spiffo
2000 conv
[Modified by spiffo, 6:02 PM 9/8/2003]
Old Sep 16, 2003 | 07:18 PM
spiffo's Avatar
spiffo
2nd Gear
Default Re: DTC code causing check engine light (spiffo)
this has now happened 4 times . . . anyone have an idea?
s
Old Sep 16, 2003 | 07:27 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
I replaced mine (4k ago), and this apparently 'fixed' the issue.
Cheap (approx $200 including labor) for piece of mind.
To DTC code causing check engine light
