Remote Entry - Resync Required
Old Sep 11, 2003 | 12:09 PM
BostonVette's Avatar
BostonVette
Default Remote Entry - Resync Required
My Transmitter keeps losing it's mind.
At first it wouldn't operate the door locks, so I replaced the battery and went thru the 7 sec resync. It worked... but not for long.
Next day had to resync.
It seems like after a period of a few hours it needs resyncing.
Anybody have any similar experiance or ideas?
I would hate to lay up the car at the dealer for this.
Tom :cheers:
Old Sep 11, 2003 | 12:43 PM
THRAP 42's Avatar
THRAP 42
Default Re: Remote Entry - Resync Required (BostonVette)
BostonVette,
Instead of a resync, try reprogramming them. Here's the instructions;
Programming Transmitters
1. Turn the ignition to ON.
2. Turn the radio to OFF.
3. Press the RESET button in order to clear any IPC warning messages.
4. Press and release the OPTIONS button on the DIC to scroll through the
display options until the IPC display is blank.
5. Press and hold the RESET button for 3 seconds.
6. Press the OPTIONS button until FOB TRAINING message is displayed.
7. Press the RESET button in order to begin the programming sequence. The
message HOLD LK + UNLK 1ST FOB will be displayed.
8. Simultaneously press and hold the LOCK and UNLOCK buttons on the first
transmitter for 15 seconds. The IPC will indicate when that transmitter is
programmed and when to proceed to the next. Repeat this procedure for
each additional transmitter or press the OPTIONS button to exit.
later,
Old Sep 11, 2003 | 03:28 PM
Jeff Jeff's Avatar
Jeff Jeff
Default Re: Remote Entry - Resync Required (THRAP 42)
I had a similar problem right when my battery started to leak acid. If you don't have an AGM battery, I would check your battery ASAP.
Old Sep 11, 2003 | 05:18 PM
ProDesign's Avatar
ProDesign
It sounds like the battery is loosing contact with the metal battery contact. This can happen if you bent the battery contacts during battery change or if they are out of position. The battery contacts are held against the battery by pressure and slight opening of the case (such as keeping it in your pocket) may cause this to happen. Try bending the battery contact located on the circuit board out slightly. Be careful not to bend too much or the contact will break off.
Prior to bending the contact, you can try leaving the key fob out on a desk overnight and verify that it does not loose its synch.
Old Sep 12, 2003 | 11:51 AM
jngoldin's Avatar
jngoldin
Default Re: Remote Entry - Resync Required (ProDesign)
I was thinking something along the same lines. Maybe the batteries are weak and need to be replaced? Does anyone know how long they last?
Old Sep 12, 2003 | 11:54 AM
racetchr's Avatar
racetchr
Default Re: Remote Entry - Resync Required (jngoldin)
Manual says about 18mos. But just replaced mine and was 3yrs and a few months. So you never know.
Old Sep 12, 2003 | 11:59 AM
jngoldin's Avatar
jngoldin
Default Re: Remote Entry - Resync Required (racetchr)
Ooops, I just read the original post a little more carefully. He did replace the batteries, so that's not it. Sorry. :cheers:
[Modified by jngoldin, 12:01 PM 9/12/2003]
Old Sep 12, 2003 | 12:33 PM
BostonVette
Thrap 42
Thanks for the input.
I'll try that approach.
My second transmitter works fine.
Will I need to reprogram the second as you suggested?
Tom
Old Sep 12, 2003 | 12:59 PM
THRAP 42's Avatar
THRAP 42
Had the same thing happen with my wifes transmitter the other day. It would not resync but once I did the reprogram if works just fine.
I would do this yes, when I did mine I reprogrammed my FOB as well. AFter the first one is programmed, the DIC will come up for the second FOB.
later,
Old Sep 15, 2003 | 12:13 PM
BostonVette
I tried the reprograming.
No change, the FOB still loses it's mind.
I'm trying the battery contacts, if that doesn't help, it's off to the dealer.
Old Sep 16, 2003 | 02:01 PM
BostonVette
Well I'll be dipped in Schit,
Tweaking the battery contacts worked... :yesnod:
The FOB has held it's memory overnite.
Turns out it was the curved finger contacts that connect the PCB on the other half.
Saved a trip to the dealer ;)
Thanks for the tip
To Remote Entry - Resync Required
