Tire pressure Q.
Old Sep 11, 2003 | 07:45 PM
pk2401's Avatar
pk2401
St. Jude Contributor
Default Tire pressure Q.
I think I'm sure when racing the 1/4 mile your tire pressures are to be at ~24 psi for the rear and ~50 psi for the front. Is it recommended to change these pressures if your racing in high temps. Going this weekend. Forecast calls for 100 F - 103 F. I think the altitude is about 2500'. All info is appreciated.
[Modified by pk2401, 4:46 PM 9/11/2003]
Old Sep 12, 2003 | 11:36 AM
pk2401's Avatar
pk2401
Default Re: Tire pressure Q. (pk2401)
Anyone?
Old Sep 12, 2003 | 12:02 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Are they the stock runcraps? We're talking 1/4 mile track right?
I ran 25 in the back at the track and didn't mess with the front. I would go a little lower, maybe 20-22. This is because after doing a few short burnouts you'll see the pressure go up on the DIC.
Remember to turn off the traction control!
Old Sep 12, 2003 | 03:39 PM
pk2401's Avatar
pk2401
Default Re: Tire pressure Q. (5 Liter Eater)
There are not the run craps. They are the stock wheels for the Z. The're Eagle F1's. And yes it will be at a 1/4 mile track. Thanks.
To Tire pressure Q.
