NGK TR55 vs TR6
Old Sep 14, 2003 | 07:00 PM
Shag Finger's Avatar
Shag Finger
Default Re: NGK TR55 vs TR6 (binksZ06)
And yes I know about how the little ends need to be tightened on the NGKs, I learned that years ago, the hard way. No, this was about 10-12 per second per cylinder on average and would set of a P0300 code.
**** Finger - What's up with the little ends? I don't know about this.TIA.
The tips where the plug wires connect are screwed on and have a tendancy to loosen over time if they are not snugged up before installation. I can't tell you how many of the guys in the GTP world had this problem when we first started using them. I just used a shop rag and a set of pliers for the tip and a boxed end wrench for the plug body. Sometimes there were so loose from the factory that they would spin off by hand :eek:
Old Sep 14, 2003 | 09:43 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: NGK TR55 vs TR6 (**** Finger)
Thanks! :thumbs:
