NGK TR55 vs TR6
Old Sep 12, 2003 | 02:02 AM
kumar75150's Avatar
kumar75150
Default NGK TR55 vs TR6
Most of you stroker or heads/cam guys, which plugs do you use?
Is there power switching from TR6s to 55s you think?
Old Sep 12, 2003 | 10:41 AM
ixlr8's Avatar
ixlr8
Default Re: NGK TR55 vs TR6 (kumar75150)
Hey Kumar you know I don't have a heads/cam car just a cam but the TR6's are a good nitrous plug because they are a colder plug the TR55's I would think in my experience are a better non/nitrous or FI plug because they burn hotter. Just my $.02
Old Sep 12, 2003 | 12:42 PM
Steve02C5's Avatar
Steve02C5
From: Renaissance Festival TAZ the Wolfdog (R.I.P.)
Prior to the S/C, MTI recommended the TR 55, afterwards, the TR6.
Old Sep 12, 2003 | 12:55 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
I'm running TR 6 plugs in a stock LS1 with bolt ons and they work fine. Checked them when the lgm headers were installed, they looked great. Ron B. :seeya
Old Sep 12, 2003 | 01:28 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Here's what I've learned
TR55- NA-stock, H&C, bolt-ons etc.
TR6-Nitrous, FI, High Compression NA
FWIW -My CR is in the Neighborhood of 11.5:1. Running TR6s and they've held up very well. I've insulted the hell out of them with 10-11 AFR idles numerous times- Burnt up the High Flow cats but the TR6s are fine!
:lol: :thumbs:
Old Sep 12, 2003 | 04:12 PM
FKING1's Avatar
FKING1
Default Re: NGK TR55 vs TR6 (binksZ06)
Have TR55's on my head & cam pkg. Had TR6 when stock. My engine builder said 6's are too cold for H/C & 55's best. I'm happy.
Fred K.
Old Sep 12, 2003 | 05:47 PM
MY1Fast99C5's Avatar
MY1Fast99C5
Default Re: NGK TR55 vs TR6 (FKING1)
I have used the TR6's for a while now and havent had any trouble out of them.
Old Sep 12, 2003 | 06:22 PM
ixlr8's Avatar
ixlr8
Default Re: NGK TR55 vs TR6 (MY1Fast99C5)
You won't have any trouble with them. It is just that the TR6's are a colder plug and the TR55s you will get a hotter spark which equates to better power. You run the TR6s in nitrous or FI cars because they are colder.
Old Sep 12, 2003 | 06:26 PM
Shag Finger's Avatar
Shag Finger
Default Re: NGK TR55 vs TR6 (ixlr8)
I uesd to use TR55s and TR6s in my blower car, but found nothing but misfires from them in the Z with the cam. I actually just switched back to Delco plugs today and the misfires went away.
One side note, the 03 called for 41-974s which are platinum. The dealer that I got mine from said that his book lists them as changing for 04 to 41-985s which are iridium and are what should replace the 974s. In any event, I put them in and the misfires went away.
And yes I know about how the little ends need to be tightened on the NGKs, I learned that years ago, the hard way. No, this was about 10-12 per second per cylinder on average and would set of a P0300 code.
Old Sep 12, 2003 | 06:32 PM
ixlr8's Avatar
ixlr8
Default Re: NGK TR55 vs TR6 (**** Finger)
Interesting.
Old Sep 12, 2003 | 07:04 PM
Sack Rat TT's Avatar
Sack Rat TT
I vote for TR-55's. TR-6's for NOX, supercharged, or turbo cars. Perhaps other cars with higher CR's etc. Good luck
Old Sep 12, 2003 | 07:50 PM
vstella's Avatar
vstella
I use the TR55's with 11.25 CR..Their OK but some detonation in hot weather..maybe the TR6 is the way to go.. :rolleyes:
Old Sep 13, 2003 | 12:47 PM
MY1Fast99C5
Exactly I havent had any issues with them being a colder plug. No fouled plugs.
Old Sep 13, 2003 | 07:33 PM
itsonlyairandfuel
:iagree:
Old Sep 14, 2003 | 01:08 AM
kumar75150's Avatar
kumar75150
Default Re: NGK TR55 vs TR6 (itsonlyairandfuel)
I was just wondering if there was any power going from 6s to 55s. I like to play it safe and stay with the TR6 and 11:1 compression but just wondering.
Old Sep 14, 2003 | 01:10 AM
Shag Finger
TR6s are a colder plug, I wouldnt see any benefit of going to the 5 series which is the next heat range hotter if you have no problems fouling your 6s.
Old Sep 14, 2003 | 02:05 PM
SFVetteman's Avatar
SFVetteman
Default Re: NGK TR55 vs TR6 (vstella)
The problem may be too hot a plug or possibly too much timing for the temp. I'd pull a plug or two and check the color. If they have a white blistered appearance then you need a colder plug. If they have a light tan/brown color they are just right.
To NGK TR55 vs TR6
Old Sep 14, 2003 | 02:10 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
**** Finger - What's up with the little ends? I don't know about this.TIA.
Old Sep 14, 2003 | 02:28 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
I never thought NGK would be put in anything besides my lawnmower but I added TR-6's about 6 months after I installed the blower and can definitely tell the car runs better, it's slightly hard starting (engine takes 1/2 second longer to fire off) but runs great. :cheers:
Old Sep 14, 2003 | 02:37 PM
Q8TY_VETTE's Avatar
Q8TY_VETTE
hi guys,
vstella, you know the weather in Kuwait is very hot, which do you think are the best plugs??
now I'm using Bosch Platinum +4 with MSD wires, what do u think??
:rolleyes: :rolleyes:
