Outside air temp
Old Sep 14, 2003 | 09:31 PM
BlueDragon's Avatar
BlueDragon
Default Outside air temp
My outside air temp is reading wrong. Where is the sensor/pickup? Is that the one that pokes into the radiator shroud on the right side down low? The panel was changed a while back for being dim, but when it is 100 degrees out it reads like 68. I either have a loose wire or dirty terminals or the sensor is toasted!
Any one have experience with this?
Jer
[Modified by BlueDragon, 8:32 PM 9/14/2003]
Old Sep 14, 2003 | 09:42 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Outside air temp (BlueDragon)
"Is that the one that pokes into the radiator shroud on the right side down low?"
:yesnod:
[Modified by C-5 TECH, 9:43 PM 9/14/2003]
Old Sep 14, 2003 | 10:29 PM
BlueDragon's Avatar
BlueDragon
Default Re: Outside air temp (C-5 TECH)
I think so, have not had time to mess with it.
Jer
Old Sep 15, 2003 | 10:55 AM
Tigger's Avatar
Tigger
There are a number of pictures and links in this thread that will answer all your questions. I changed mine about 4 weeks ago, and it took about 10 min.
:D :D
http://forums.corvetteforum.com/zero...640#1544843640
Old Sep 15, 2003 | 11:17 AM
BlueDragon's Avatar
BlueDragon
Default Re: Outside air temp (Tigger)
Thanks Tigger,
Finally got off my dead butt and opened up the manuals. reseated the connector, and will check it out. If it still acts up I will change it later today. I was concerned that it was a input for something other than the AC but it appears that only the AC head uses it! and for $8 bucks, I will swing into the dealership and pick one up. The thread you sent was useful, will save me a bunch of time.
Jer
Old Sep 16, 2003 | 09:31 AM
BlueDragon's Avatar
BlueDragon
Ah, reseated the corn-necter and it seems to have healed for the time being. Interesting little gizmo and the check out routine for the AC system, reads like a launch plan for a space ship in the maint manual!
jer
To Outside air temp
