Braking Question
Old Sep 15, 2003 | 01:12 PM
GR8-LIFE's Avatar
GR8-LIFE
Default Braking Question
Which makes the bigger difference from stock in terms of stopping power - Different PADS or Different Rotors?
Which brand of both is recommneded - not for looks, but for pure stopping power?
Old Sep 15, 2003 | 01:25 PM
gonbad's Avatar
gonbad
Default Re: Braking Question (MARK's_C5TT)
The pads will make the most difference.
Drilled rotors both remove mass and surface area reducing the friction surface and reducing thermal mass. Brake rotors operate as a heatsink. Drilled rotors are prone to cracking under hard driving conditions.
Slotted rotors are better than drilled as they are not prone to cracking. However their effect is probably negligable considering modern pad materials that resist glazing and out gassing.
The biggest determining factor in braking distance and feel is TIRES. Mount some competition rubber on all four corners of the C5 and you will think you just mounted a huge big brake kit on the car. The only reason to use the big Wilwood or Bear kits is for use on track cars only. The pads used by these systems are often not suitable for street use. They need high heat to work properly.
