Educate Me!!!!!
Old Sep 15, 2003 | 05:20 PM
2KFRC5's Avatar
2KFRC5
Default Educate Me!!!!!
I've read about spark plugs missing pucks. I've worked on my own vehicles for many years, looked at a lot of plugs, but have never seen what I would call a puck.
Some one please draw me a picture. What is a puck???? :confused:
Old Sep 15, 2003 | 06:33 PM
knewblewkorvette's Avatar
knewblewkorvette
Default Re: Educate Me!!!!! (2KFRC5)
I always thought a "puck" was the devices you put between the tire jack and the frame of the Corvette :confused:
Old Sep 15, 2003 | 06:37 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Default Re: Educate Me!!!!! (knewblewkorvette)
I am pretty sure that the "puck" is the ceramic insulator surrounding the electrode or perhaps the entire insulator and electrode together :confused: :D
Old Sep 15, 2003 | 06:40 PM
DocSandy's Avatar
DocSandy
From: When I say who is the mastah you gotsta say Shonuf
Below is a photo of the NGK TR55(left) plug next to a Delco Platinum stock(right). Notice the platinum "puck" on the outer electrode of the delco plug, which is prone to breaking or falling off.
Thank you, Vetteguru
[Modified by DocSandy, 5:42 PM 9/15/2003]
Old Sep 15, 2003 | 06:41 PM
C7GrandSport's Avatar
C7GrandSport
I've heard of hockey goalies missing pucks. It's called a goal.
Old Sep 15, 2003 | 07:38 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
I dont give a puck !!! :eek:
Old Sep 15, 2003 | 07:53 PM
2KFRC5's Avatar
2KFRC5
Default Re: Educate Me!!!!! (DocSandy)
knewblewkorvette, c5grandsport, I was thinking along the same lines as both of you. :D That is until DocSandy educated me. :thumbs: I don't ever recall using plugs that had these pucks. That is a new one for me.
Thanks, DocSandy, for the link to the photo hosted by VetteGuru.
Thanks to all for your input.
[Modified by 2KFRC5, 4:56 PM 9/15/2003]
Old Sep 15, 2003 | 07:59 PM
chuckster's Avatar
chuckster
Default Re: Educate Me!!!!! (c5grandsport)
Well then my motor scored a "HAT TRICK" before I replaced thos crappy plugs!! :rofl:
Old Sep 16, 2003 | 09:25 AM
knewblewkorvette
Default Re: Educate Me!!!!! (chuckster)
Why would they put these pucks on the plugs in the first place?
Do the aftermarket plugs for the Corvette have these as well?
Old Sep 16, 2003 | 12:33 PM
Richin Chicago's Avatar
Richin Chicago
It is the bottom piece of platinum lashed to a conventional plug. They don't seem to have a good high speed process to join the dissimilar metals.
Old Sep 16, 2003 | 02:14 PM
Mitch Alsup's Avatar
Mitch Alsup
A surface of high curvature has high electric field gradient. A high electric field gradient creates a spark at lower voltage than a lower field strength. So, in effect, the puck concentrates the electric field and allows a lower voltage to initiate a spark.
Old Sep 16, 2003 | 02:46 PM
knewblewkorvette
Default Re: Educate Me!!!!! (Mitch Alsup)
That all make sense. Do the aftermarket plugs for the vette have them?
According to some on the forum, the pucks fall off. Won't that screw up the spark and therefor the running of the engine? Would not the falling puck also cause the engine physical damage? Do I need to run out and replace them now???? :confused: :confused:
Old Sep 16, 2003 | 03:16 PM
tpocock's Avatar
tpocock
No, the pucks fly out the exhaust valve just like an occasional flake of carbon. Most of the time there is no change in function after they fly off, though the plugs may not last as long as advertised. The pucks are there in an attempt to get the plugs to last 100,000 miles.
Old Sep 16, 2003 | 05:39 PM
2KFRC5's Avatar
2KFRC5
According to some on the forum, the pucks fall off. Won't that screw up the spark and therefor the running of the engine? :confused: :confused:
Now that I know what a puck is, maybe I can help answer this.
The puck, made from platinum, has a higher melting point than the normal copper electrode. Therefore it increases the mileage that the plug will normally last by not burning off and increasing the plug gap over a longer period of time.
If the puck does fall off, then that will increase the plug gap (by the thickness of the puck) and could possibly effect the performance of the engine.
I believe others who have used the TR55 say they are better(?), but don't last as long. That's because they are regular copper electrode plugs and don't have the platinum pucks to protect the electrodes.
:eek: :eek:
[Modified by 2KFRC5, 5:09 PM 9/16/2003]
Old Sep 16, 2003 | 07:01 PM
irfgt's Avatar
irfgt
Default Re: Educate Me!!!!! (tpocock)
I think the problem is being a little overblown as I have removed hundreds of these plugs and have never seen this happen. I am not saying it doesn't but I have never seen it and sure am not running out to replace my plugs for that purpose.
Old Sep 16, 2003 | 08:08 PM
Richin Chicago
Default Re: Educate Me!!!!! (irfgt)
I wonder what the difference is? I shared my findings with our club members and I don't know of anybody that hasn't had, at least, a few pucks missing.
The only exeption had been people that didn't have the Delco plugs installed in the first place. I wonder if it only occurs with cars that see a lot of redline?
Old Sep 17, 2003 | 06:46 PM
1vette98's Avatar
1vette98
I pulled the plugs in my '98 at 34,000 and only 2 had the pucks still there. I pulled the plugs (also Delco Platinum) out of my Tahoe at 100,000 and all the pucks were still there. What's up with that?
To Educate Me!!!!!
Old Sep 18, 2003 | 02:50 PM
jmX's Avatar
jmX
Then I beleive you are looking at the wrong thing. After doing plug changes on at least 10 LS1's, every single engine has had at *least* one puck missing, and some had 4-5 missing. What you are saying sounds almost unbeleivable based on my, and other locals, experiences.
Jon
http://www.ls1howto.com
Old Sep 18, 2003 | 03:04 PM
VetteDrmr's Avatar
VetteDrmr
Default Re: Educate Me!!!!! (jmX)
Jon,
When I changed out the plugs on my '94 Z-28 (LT-1), 5 of the 8 plugs were missing their pucks. I just recently changed out the plugs on my '00 hardtop with 105K+ miles, and they ALL had their pucks intact. I'm fairly certain they're the original plugs, since most everything else I've replaced on this car has been original, and it had that "way too tight" feel of original manufacturing.
BTW, I replaced mine with NGK TR-55s.
I have read (and my recent experience backs this up), that they got whatever problem was causing the pucks to be lost solved in the late 90s.
HTH, and have a good one,
Mike
Old Sep 18, 2003 | 03:27 PM
Richin Chicago
Default Re: Educate Me!!!!! (VetteDrmr)
Jon,
Mike
Maybe they fixed it after 2000 but my car had several missing and others in the 99 00 timeframe had pucks missing. I have been told this problem goes all the way back to Lt1/4 from the time they introduced 100,000 mile tueups.
So if they fixed it it took an extraordinary amount of time.
