Hi Beam Headlamps?
Old Sep 15, 2003 | 11:43 PM
ActionJackson's Avatar
ActionJackson
Default Hi Beam Headlamps?
When the High Beam Headlamps are ON, are the Low Beam Headlamps supposed to go OFF? Is this normal for C5?
(On both of my other cars, when the High Beams are ON, the Low Beams are also ON.)
If so, is there a mod for both High Beam and Low Beam to be on at the same time?
I've installed the higher wattage APC Super Whites (80W - low and 100W - high), so would this be a problem if both were On at the same time?
Old Sep 16, 2003 | 04:16 AM
TGrits10's Avatar
TGrits10
Default Re: Hi Beam Headlamps? (ActionJackson)
Yeah it's normal, not sure why they do that, I hate how the bottom of my field of vision isn't illuminated with the highs on, only up in the trees :rolleyes:
If someone came up with a mod for this, I would be their slave forever:yesnod:
Old Sep 16, 2003 | 08:13 AM
Bob Chapman's Avatar
Bob Chapman
Default Re: Hi Beam Headlamps? (TGrits10)
I saw a kit somewhere that allowed you to have both high and low lights on when you turn on the high beams. Don't remember where - but it might be worth a search.
Old Sep 16, 2003 | 09:58 AM
Miaugi's Avatar
Miaugi
Default Re: Hi Beam Headlamps? (Bob Chapman)
I'd be interested in this as an option as well. Maybe one of our electrical guru's can come up with a simple wiring mod???
To Hi Beam Headlamps?
