Hypertech programmer for an LS1
Old Sep 17, 2003 | 11:17 AM
SLICKMAN's Avatar
SLICKMAN
Default Hypertech programmer for an LS1
Hypertech programmer for an LS1, will this give me the ability to change the on temp of the radiator fan?
Old Sep 17, 2003 | 11:21 AM
BLACK86's Avatar
BLACK86
From: Marblehead, Mass, 2003 Corvette Convertible Black/Black/Black
Default Re: Hypertech programmer for an LS1 (SLICKMAN)
hello
Yes. The Hypertech programmer will give you the ability to change the on temp of the radiator fan.
Old Sep 17, 2003 | 11:57 AM
SLICKMAN's Avatar
SLICKMAN
Default Re: Hypertech programmer for an LS1 (BLACK86)
Great thanks!!!
Old Sep 19, 2003 | 10:46 PM
NIGHTMARE...2001's Avatar
NIGHTMARE...2001
Yes...that and much, much more!!! I have my 2001 LS1 HP111 programmer for sell right now, if you want one! :cheers:
Why don't you start a thread on the forum, to see if the 2001 programmer will work with your car? :)
[Modified by NIGHTMARE...2001, 9:22 AM 9/20/2003]
Old Sep 20, 2003 | 09:24 AM
martin97c5's Avatar
martin97c5
Default Re: Hypertech programmer for an LS1 (NIGHTMARE...2001)
nightmare will yours work on a 97?
Old Sep 20, 2003 | 10:07 AM
NIGHTMARE...2001
Default Re: Hypertech programmer for an LS1 (martin97c5)
I don't know for sure. You would have to call Hypertech direct, or one of your local tuners.
If you find out it will work, im me and I'll let you have it at a price you can't refuse. I know these can be bought for $335 now, but when I bought this one, the program wasn't on the market, and Hypertech charged me $500 for a "direct purchase". :cheers: You can have it for $250, as I can't use it anymore, now that I'm on LS1 edit. :cheers:
[Modified by NIGHTMARE...2001, 9:25 AM 9/20/2003]
Old Sep 20, 2003 | 11:35 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
They are year-specific. The '01 will not work with a '97.
Old Sep 20, 2003 | 07:11 PM
midnightcorvette's Avatar
midnightcorvette
is the hypertech a good choice for a 98 A4, im planning on using a TQ convertor and a 3.42 rear change...is the hypertech a good option...oh and im also doing the thermostat change
Old Sep 21, 2003 | 09:53 AM
NIGHTMARE...2001
Default Re: Hypertech programmer for an LS1 (midnightcorvette)
Yes, the Hypertech will help in all those areas. :)
Old Sep 21, 2003 | 12:05 PM
lost's Avatar
lost
Works well with my 98 A4.Besides turning fans on earlier, I firmed up the shifts and raised my shift rpm. Also have the engine program installed. Picked up .2 in the quarter. You can buy them used for around $200
Old Sep 21, 2003 | 12:21 PM
ToplessTexan
Read up on the gear change programming options. HPP3 is not a good option for non-stock ratios.
Old Sep 21, 2003 | 06:08 PM
midnightcorvette
Default Re: Hypertech programmer for an LS1 (ToplessTexan)
so general concensus? will the hpp3 be good or bad for me?
Old Sep 21, 2003 | 06:24 PM
ToplessTexan
Your programming options are limited by being for an early PCM gear change. HPP3 works for early years but won't help with the gears you want, so it's not an option in your case. Predator doesn't do early PCMs, so also not an option. Superchips is about the only option among handhelds. (IIRC, it's also more expensive, in line with mail order pricing.) Other than that you're looking at mail order or LS1-Edit programming. If you don't swap gears, the HPP3 would do just fine.
Old Sep 21, 2003 | 07:01 PM
midnightcorvette
thanks alot toplesstexan......one more question.....is superchips a good handheld unit? ive looked into them a little but i dont hear a whole lot about them
Old Sep 22, 2003 | 09:40 AM
ToplessTexan
They were the first handheld to crack the '01 code so there was a rush of of excitement back then but you don't hear too many folks using them compared to others. I have no reason to think you'd have issues, I've had Superchips tuning in my Ford for a few years although it wasn't by way of hand-held. It's sort of like the Diablo thing in that it's a semi-custom tune. Of course my preference would be LS1-Edit if you're a tinkerer at all. :D Very easy to do the things you're wanting to do now and you can grow into it at your own speed.
To Hypertech programmer for an LS1
