jesel rockers
Old Sep 18, 2003 | 01:23 AM
X_03_Cobra_guy's Avatar
X_03_Cobra_guy
Default jesel rockers
Anybody install the jesel non-adjustable rockers on the C5? I got em but valve covers don't fit.
I saw a post before that stated that the spacers create other coil pack clearence problems? :confused:
Old Sep 18, 2003 | 01:30 AM
intel55's Avatar
intel55
Default Re: jesel rockers (X_03_Cobra_guy)
I have the J2K adjustables and they would not fit. You can get a spacer from ARE or SAM racing. Extreme might even have them. I have not heard about any problems with the SAM spacer. That would be new to me.
I have custom valve covers, so I never needed a spacer.
[Modified by intel55, 12:32 AM 9/18/2003]
Old Sep 18, 2003 | 01:49 AM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: jesel rockers (intel55)
1) You can get a valve cover spacer, but they're prone to leaks and require longer spark plug wires.
2) Buy the GM Perf Parts C5R covers. Better Option, but more pricey.
:cheers:
Old Sep 18, 2003 | 01:59 AM
cfi_luz's Avatar
cfi_luz
Default Re: jesel rockers (BQuicksilver)
Are these the 700.00 shaft mount rockers? If so, I thought they were adjustable. thanks
Old Sep 18, 2003 | 02:00 AM
BQuicksilver
Default Re: jesel rockers (cfi_luz)
They are, but the adjustment doesn't make them fit better under the cover.
Old Sep 18, 2003 | 02:07 AM
intel55's Avatar
intel55
Not the $700 ones. THe J2K are and they go for around $950. Jessel maes the adjustable and "SS" nonadjustable.
Extreme may be able to get you the valve covers I got a couple years ago. They are ALOT better than the Katech ones... alot lot lot better.
[Modified by intel55, 1:10 AM 9/18/2003]
Old Sep 18, 2003 | 09:03 AM
marco383's Avatar
marco383
The stock valve covers can be modified to clear the non-adjustable Jesels by removing all of the internal oil baffling. To avoid a lot of oil getting into the LS1 PCV system, the LS6 PCV setup (vacuum being pulled from the valley cover rather than one of the valve covers) should be installed in conjunction with this mod.
I've just switched to Katech's new valve covers, so if you're interested in my modified originals, they're yours for a pittance.
Old Sep 18, 2003 | 09:34 AM
X_03_Cobra_guy
Default Re: jesel rockers (marco383)
Where did you get the Z06 PCV valve mod? Thanks for the info :seeya
Old Sep 18, 2003 | 10:05 AM
Operations's Avatar
Operations
What kind of HP are these worth? 8-10?
Old Sep 18, 2003 | 10:11 AM
marco383's Avatar
marco383
Just buy the LS6 valley cover and associated hoses from your friendly Chevy dealer. The mod takes the valve covers out of the PCV system, making the stock baffling unecessary for control of oil ingestion. Some dental work is required on early blocks to clear the LS6 valley cover baffle, but this shouldn't be a problem for anyone with a degree in Dremel tool.
Someplace, there is an LS1 wbsite that gives you a step by step tutorial for this mod, complete with photos. I just can't remember the address, but I'm sure that another forum member will.
Old Sep 18, 2003 | 11:06 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: jesel rockers (Operations)
With stock ratio, I bet you would be lucky to get 3-5rwhp out of a set of these rockers. However, their lighter weight and excellent construction definitely improve the valvetrain as far as longevity and sound goes.
They aren't worth it unless you are running a pretty high lift cam IMO. The stock ones last quite awhile even with agressive cams!
Old Sep 18, 2003 | 01:35 PM
C5-VERT's Avatar
C5-VERT
Default Re: jesel rockers (MattG)
Is there any benefit of going with Jesels over Yella Tera's? I am thinking about putting a set on mine b/c my valvetrain is pretty loud.
Old Sep 18, 2003 | 02:24 PM
marco383's Avatar
marco383
Default Re: jesel rockers (C5-VERT)
If the YTs are shaft mounted, probably not. The shaft mount provides extra stability for high lift cams, especially under conditions of sustained high revs, as in road racing.
Old Sep 18, 2003 | 02:39 PM
C5-VERT's Avatar
C5-VERT
Yes they are shaft mounted, but the mount is not one piece like the jesels. Hard to explain. A picture would make more sense...
Old Sep 18, 2003 | 02:44 PM
intel55's Avatar
intel55
I think the Jessels are of higer quality. But that is just my opinion. IF you get the J2K (adjustable) and have bigger valves you will need a custom shaft mount from them. It needs to be a tiny bit taller.
Old Sep 18, 2003 | 11:37 PM
X_03_Cobra_guy
I got the jesels for reliability with heavy springs and a bigger cam. I really want to keep it all under
the stock covers if possible. The cam is a .580 lift and removing the baffles may work. I think I'll bolt the covers on the heads with the rockers and valves installed with no springs and measure how much
lift there is available without the baffles. Hopefully there will be enough. Then I will do the Z06 PCV trick mentioned above. Hopefully I can find it using the search feature.
Old Sep 18, 2003 | 11:48 PM
intel55's Avatar
intel55
Oh I almost forgot on my Jessel J2K's I also had to slighlty clearance the head on the exhaust side railing. I have LQ9 heads which really should not matter, but still needed to be clearanced for the adj. rockers. :cheers:
To jesel rockers
Old Sep 18, 2003 | 11:52 PM
intel55's Avatar
intel55
Ok here is a pic... more than I remember I guess :D :D
Old Sep 19, 2003 | 01:43 AM
X_03_Cobra_guy
Thanks marco383. I found the tutorial at:
http://www.ls1howto.com/index.php?article=18
Cool! I got the GM parts ordered from Scoggin-Dickey 60 odd bucks worth.
The Z06 PCV system is the way to go then remove all the baffles and grind off
a few bumps and I think it'll be good to go. :smash:
Old Sep 19, 2003 | 10:11 AM
Louis @ LG Motorsports's Avatar
0Louis @ LG Motorsports
Former Vendor
If you do not want to deal with new valve covers and coil relocation kits, We now offer a spacer that will work with the Corvettes.
The Spacers currently on the market will not clear the altenator as they were designed for an Fbody.
Give us a call, PM me, or talk to Lou if you are interested in them :steering:
Louis
http://www.LGMotorsports.com
[Modified by Louis @ LGM, 3:12 PM 9/19/2003]
