Tranny question
Old Sep 21, 2003 | 02:21 PM
402Sam's Avatar
402Sam
Default Tranny question
Does are car come already plumbed for tranny cooler lines. Also is the radiator plumbed to. When I get my stall installed, I want to put a transmisson cooler on also.
Old Sep 21, 2003 | 02:38 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: Tranny question (sprayedc5)
If your car came with an automatic transmission then you will have 2 hard lines going from the transmission to the radiator for fluid cooling
Old Sep 21, 2003 | 02:41 PM
402Sam's Avatar
402Sam
Default Re: Tranny question (runamuk)
So its all set up for the cooler or are you saying there is already a type of cooling goin on and I wont need a cooler. Oh I do have a a4.
Old Sep 21, 2003 | 02:50 PM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
Yep your auto has a cooler in the radiator already. Are you installing a higher stall torque converter?
If so, IMO (and I have already done this on an auto) if you are going with a say Yank 3000, I would install it and simply use the stock tranny cooler in the radiator and watch the temps. Most likely you will be OK with the stock cooler alone with a Yank 3000. The Yanks are VERY efficient.....I DID NOT need an additional cooler with my Yank 3000 as the temps were perfect. When I installed the stroker and the SY3500, I installed an additional B&M 24,000GVW unit which supplemented the stock cooler in the rad. In the Summer the temps are perfect but I do believe in the Fall and Winter it will keep the temps too cool!!!!!! I upgraded to a BeCool high capacity rad so that is defintely helping keep it cooler.
Keep in mind running too cool IS NOT a good thing that's why I say install the torque converter and see what your temps are at...if they are too high then simply add the additional tranny cooler. Very easy! If you run too cool you will have torque converter lock-up issues for sure which is not good and can prematurely trash your tranny!
[Modified by Buckmaster, 2:52 PM 9/21/2003]
To Tranny question
