X pipe install
Old Sep 21, 2003 | 04:11 PM
FlyinNOE's Avatar
FlyinNOE
Default X pipe install
Does anyone have a good link for an x pipe install?
I've been looking all afternoon. I'm just curious if I have to cut my stock Ti exhaust, or if the Magnaflow, Bassani, Corsa units are bolt in. :confused:
Thanks in advance. Back from Iraq and spending time on the car before reporting to Korea for the next year :rolleyes:
Brian :flag
Old Sep 21, 2003 | 04:30 PM
STEPHEN H. SMITH's Avatar
STEPHEN H. SMITH
Default Re: X pipe install (FlyinNOE)
Try Random Technology. Ask for Clay. I think they make units that are direct fis for either stock or headers.
Old Sep 21, 2003 | 05:21 PM
FlyinNOE's Avatar
FlyinNOE
Default Re: X pipe install (STEPHEN H. SMITH)
Thanks for the info.
Brian
Old Sep 21, 2003 | 05:45 PM
Scubanme's Avatar
Scubanme
I just did an X-pipe install not too long ago and you won't need to cut anything on the cat-back section. You will need to cut your H-pipe section
after the cats. Then you slide the X-pipe section over the stock pipes right after the cats. It is a slip-fit deal that you use muffler clamps to hold together.
Good luck :flag
Old Sep 22, 2003 | 04:58 AM
markcz's Avatar
markcz
They should all be about the same, just a different length. Here are the SLP instructions.
http://www.slponline.com/inst/30066.pdf
:cheers: :flag
Old Sep 22, 2003 | 10:09 AM
FlyinNOE's Avatar
FlyinNOE
Thanks for your help guys. That's what makes this forum great. :thumbs:
Brian :flag
[Modified by FlyinNOE, 3:09 PM 9/22/2003]
Old Sep 22, 2003 | 10:13 AM
Patches's Avatar
Patches
This is a good install/test article on the Magnaflow x-pipe.
http://www.vetteweb.com/tech/0307vet_xpipe/
To X pipe install
