Old Sep 21, 2003 | 10:57 PM
SSTRUCKNGUY's Avatar
SSTRUCKNGUY
Default 427.....
anybody droped a 427 in their c5??if so or if not what kinda ponies is this bad boy putting out??? for 20G's it better throw me against my seat....
Old Sep 21, 2003 | 11:50 PM
kumar75150's Avatar
kumar75150
Default Re: 427..... (SSTRUCKNGUY)
Most 427s cost around $15000-16000ish and put out around 480-520hp and tq.
Old Sep 22, 2003 | 12:01 AM
SSTRUCKNGUY
Default Re: 427..... (kumar75150)
ok the pros are more power and tons of fun. are there any cons to doing this swap???im sure the suspension is affected because of the added weight, ill need a beefed up tranny and brakes, cooling system etc....
Old Sep 22, 2003 | 12:03 AM
kumar75150's Avatar
kumar75150
I dont think there is much if any added weight unless you choose an iron block for your application.
You wont need suspension changes etc.
You will need bolt ons to make that kind of power. Headers, exhaust, intake, pulleys, throttle body etc.
Also, depending on who you go with, you will most likely have an aftermarket warranty on the motor so you dont have to worry about immediate reliabilty.
Old Sep 22, 2003 | 12:04 AM
kumar75150's Avatar
kumar75150
BTW you might want to upgrade the brakes just to handle the extra power but thats not really a requirement.
Old Sep 22, 2003 | 12:20 AM
kh24's Avatar
kh24
Upgrading the brakes, tranny, clutch, and output shaft are a good idea to do while the car is apart. I wish I had better brakes on my car cause sometimes it is hard to stop when you can get up to speed so fast.
Old Sep 22, 2003 | 12:38 AM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: 427..... (kh24)
You hit the nail on the head. Upgrading my brakes was more dramatic than my big bore motor on the juice! :yesnod:
Old Sep 22, 2003 | 12:55 AM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
Why spend all that money to acheive something that a good heads and cam with a good set of headers and exhaust can get you or very close to it?
Old Sep 22, 2003 | 01:31 AM
kumar75150's Avatar
kumar75150
Default Re: 427..... (Roofless)
Cause
1) a lot more tq
2) lot more area under the curve
3) pretty much bulletproof bottom end and ability to take more abuse
Old Sep 22, 2003 | 01:45 AM
BLUTHUNDER's Avatar
BLUTHUNDER
Cause
1) a lot more tq
:iagree:
To 427.....
