Do you changed the fuel filter?
Old Sep 22, 2003 | 12:10 AM
TigerVette's Avatar
TigerVette
Default Do you change the fuel filter?
Do you change the fuel filter and at how many miles? I checked out the filter today and it looks pretty straight forward except one thing: How do you remove the fuel feed pipe from the outlet connection? The service manual only says to disconnect it but doesn't say how. Thanks for replies in advance.
Don
:grouphug:
[Modified by TigerVette, 11:12 PM 9/21/2003]
[Modified by TigerVette, 11:15 PM 9/21/2003]
Old Sep 22, 2003 | 01:46 AM
ScreaminDemon's Avatar
ScreaminDemon
Default Re: Do you change the fuel filter? (TigerVette)
You need a fuel line disconnect tool, I don't remember the size but it is really small.
Old Sep 22, 2003 | 11:08 AM
texasredc8's Avatar
texasredc8
Default Re: Do you change the fuel filter? (ScreaminDemon)
AutoZone carries the plastic tool. Very inexpensive. I saw them on the rack last time I was there.......... $10
Just make sure you get the correct tool for GM, as there were about 15 different models to choose from.
Old Sep 22, 2003 | 11:10 AM
Bandit1's Avatar
Bandit1
Default Re: Do you change the fuel filter? (TexasRedZ06)
:iagree: Try this for a tech tip-- https://www.corvetteforum.com/techti...=123&TopicID=1
Old Sep 22, 2003 | 11:58 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Do you change the fuel filter? (Bandit1)
changed the filter @ 50000... It was 1/2 clogged... after replacing the filter... My fuel pressure went down to 56lbs from 58lbs
Old Sep 22, 2003 | 01:02 PM
TigerVette's Avatar
TigerVette
Thanks, you guys are a big help.
:cheers:
Don
To Do you changed the fuel filter?
