2001 Oil consumption Q
Old Sep 22, 2003 | 11:20 PM
dads01dream's Avatar
dads01dream
Default 2001 Oil consumption Q
Hey all,
Just curious, is the oil problem only happening with a minority of the '01s out there? I haven't noticed it on mine, but then again I don't have very many miles. Could this problem be waiting for me around the corner?
Any Vette techs please check in. Thanks!
Old Sep 23, 2003 | 09:44 AM
kosbe's Avatar
kosbe
Default Re: 2001 Oil consumption Q (dads01dream)
It seems either you are going to have a problem or you will not. I have read other posting on this subject in the past. Some do, some don't. I have had my '01 for about eighteen months, does not use oil. Good luck. :seeya
Old Sep 23, 2003 | 01:49 PM
C5X2C's Avatar
C5X2C
I needed to add my first quart of oil at 260 miles. I was using a quart every 1600 miles and after much debate, reringed it. Haven't had problems since. You won't develope the problem if it has not happened yet.
Old Sep 23, 2003 | 03:32 PM
Rob 2K1's Avatar
Rob 2K1
Automatics are less prone to burn oil since they are typically not driven in high RPM/ low load conditions. Some manual drivers just keep it in a lower gear in traffic and create the situation above.
You should be fine if you are not burning oil now.
Old Sep 23, 2003 | 04:32 PM
vstella's Avatar
vstella
I was consistently losing oil in my stock motor ALL the time. Now even with my 382 stroker I still use a little more than I would like...BUT ...with Royal Purple in my last oil change...so far ..NO LOSS.. :rolleyes:
Old Sep 23, 2003 | 05:24 PM
NJVetteGuy's Avatar
NJVetteGuy
Default Re: 2001 Oil consumption Q (vstella)
Mine used a quart in 1900 miles, I had it re-ringed at 13k, and it hasn't used a drop since. I didn't lose performance, times and dyno are in my sig :cheers:
Old Sep 23, 2003 | 07:01 PM
DocSandy's Avatar
DocSandy
From: When I say who is the mastah you gotsta say Shonuf
What's Royal Purple?
Old Sep 23, 2003 | 08:56 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Default Re: 2001 Oil consumption Q (DocSandy)
Royal purple is a brand of motor oil. It's good stuff, but expensive from what I hear. As for some having the problem and some not.... I think it's :bs . It's all about how you drive them. They all have the same low tension rings. The harder you drive them and the more high rpm/lowload usage the more ring flutter. Also, it can just pop up if you change how you drive the car.
Mine's burnt 5 quarts in 6300 miles. The previous owner put 11.9k on the car and babied it. He didnt' have any problems with it. Then I got it and I drive the car pretty hard and like to match rev/downshift comming to stops now it likes to burn some oil. I'm going to get the consumption test done to see what happens
Old Sep 23, 2003 | 11:26 PM
Most of the oil consumption problems are with the '01s but I had it with my '00. They supposedly fixed it in '02 with redesigned rings. Just keep an eye on it - however, you may not have much warranty left to determine whether it is using oil or not. May want to drive it a bit more. :steering:
Old Sep 24, 2003 | 01:10 AM
DocSandy's Avatar
DocSandy
Default Re: 2001 Oil consumption Q (JDs00PewterCoupe)
The car takes 7 quarts.
At how many quarts left does the "low oil" display show up on the DIC?
To 2001 Oil consumption Q
