freekin pinging!!!!!
Old Sep 23, 2003 | 04:48 PM
dsky's Avatar
dsky
Default freekin pinging!!!!!
in a previous post i described a pre-ignition-pinging, very minor, under slight accelleration. the knock sensor would catch the ping and retard the ignition, but it was audible for a moment. after investigation of it seems that the pinging is temp related, anything over 198 degrees, i get the pinging, below it runs beautiful...i know, i know run under 198degrees.....anyway what are your thoughts, bad t-stat? i am not sure the fans are turning on, what does you engines run at?
the car, a 1998 LS-1, A4 coupe with 30K miles.
help guys!!!
regards
Doug :jester
Old Sep 23, 2003 | 04:56 PM
carpe dm's Avatar
carpe dm
Default Re: freekin pinging!!!!! (dsky)
This sometimes happens with low octane gas or when we get some "bad" gas. Get the highest octane you can at your next fill-up. You might want to add a can of injector cleaner too. It could, of course, be many other things, but this is worth a try. :yesnod: :)
Old Sep 23, 2003 | 05:31 PM
pastorbrad's Avatar
pastorbrad
St. Jude 15 Year Donor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
That may be something that's been fixed in later models? I had that problem in really hot ambient temps (whether or not engine temp was high) with my 99 but my 03 didn't do it at least this summer. Bad gas? Who knows what's coming out of the pumps these days... :seeya
Old Sep 23, 2003 | 05:45 PM
dsky's Avatar
dsky
Default Re: freekin pinging!!!!! (pastorbrad)
93 octane, i even put some 104 boost in there, no dif.....
Old Sep 23, 2003 | 05:52 PM
2ndVette's Avatar
2ndVette
whta's the octane rating for premium in Florida? If it is 91 like it is here in California, high temps and low octane premium can produce pinging. Your thermostat and fans are fine, the fans just don't kick on until about 220 degrees or so. For grins, turn on your AC and you will hear the fans kick on.
Not much you can do unless you retard your timing , lower the temps or use a couple of gallons per tank of toluene or Xylene or race gas.
Old Sep 23, 2003 | 05:56 PM
98VETTEC5's Avatar
98VETTEC5
Default Re: freekin pinging!!!!! (2ndVette)
Just so you all know...
If you can hear the ping it is very bad, most detonation is not loud enough to hear. So if can hear your car ping I would find out what is causing it ASAP
Old Sep 23, 2003 | 08:18 PM
tpocock's Avatar
tpocock
Default Re: freekin pinging!!!!! (98VETTEC5)
I agree. I have had no pinging at 105deg ambient even with "bad" California gas.
Could also be bad plugs, plug wires, or carbon build up.
Still, injector cleaner is a good first start, but sounds like you will need a more thorough investigation.
Old Sep 23, 2003 | 08:31 PM
Bob Chapman's Avatar
Bob Chapman
Default Re: freekin pinging!!!!! (tpocock)
I was advised by a good dyno tuner to only run premium gas from certain companies namely - Mobil, BP and Citgo. I have followed this advice and notice a decrease in pinging [pre-ignition]. I used to run the cheapest premium I could find but then the tuner also asked the question - "why do you need to run the cheapest gas you can find in your $50,000 car?" Now I don't worry about the price of gas - just the quality.
Old Sep 23, 2003 | 08:43 PM
Jackal's Avatar
Jackal
Perform the top engine cleaning procedure found in the help section. That got rid of my ping.
Old Sep 23, 2003 | 09:05 PM
boomer 33's Avatar
boomer 33
Default Re: freekin pinging!!!!! (Jackal)
I have been through all of this, tried various remedies, and GOT RID OF IT, but, now it is back also. The cleaner that GM sells is the best start, I can't remember eactly what it is called but is something" 23458", the parts guy will know what you are talking about.
Beyond that, I know that Citgo Premium (93) is by far the best, but, there is always the unscrupulous gas station that will dump regular unleaded into the Premium tank for the extra profit. I have confirmed it happens (from an ex delivery driver). Although I have made waves, I have not been able to get anyone to admit to it. The station blames the delivery company. The delivery company claims no knoweledge of it. Most consumers don't know the difference because they don't have cars that really need it. I hope as a group we can stop this theft by confronting the managers and regional managers of the gas stations we use.
It is very simple logic that if your vette hauls butt with no ping, you pull into the station and fill up (I almost always wait until the DIC tells me it is 70 miles and out) and when you pull out and accelerate hard the ping is back, you have been shanked!
Old Sep 23, 2003 | 09:09 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
:iagree: DECARBONIZATION -here is the Tech Tip Link https://www.corvetteforum.com/techti...=212&TopicID=1 Good Luck.
Old Sep 23, 2003 | 09:16 PM
RskyBns's Avatar
RskyBns
:thumbs: :yesnod: :cheers:
Old Sep 23, 2003 | 10:39 PM
dsky's Avatar
dsky
Default Re: freekin pinging!!!!! (RskyBns)
well we'll see how it goes, i'll do the decarbonizing sat morning, let ya know how it turns out
Regards
Doug :jester
Old Sep 26, 2003 | 07:10 PM
HotLaperC5's Avatar
HotLaperC5
I had the same problem with my 99 hardtop at about 45k miles. It was definitely heat related. High temps in the summer just did a number on that car. Had it checked out a number of times w/o a real fix rendered. It got to the point where I couldn't even run the AC w/o that nasty pinging sounding off.. :mad It was Embarrasing ...your nice pristine Vette sounding like a old beater ready for the junkyard.
I finally fixed the problem though......... I got a new Vette in 02! Suddenly all my overheating problems went away ! :yesnod:
Old Sep 26, 2003 | 07:32 PM
MTWallet's Avatar
MTWallet
Default Re: freekin pinging!!!!! (HotLaperC5)
Have you thought about changing to a colder plug like a NGK TR6. they worked for me.
Old Sep 26, 2003 | 11:51 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
:iagree: :seeya
Old Sep 27, 2003 | 07:44 AM
i_york's Avatar
i_york
I have a 99 with 33k miles... no pinging except with Hypertech Power Tuning!! Even using 93-octane stuff (Shell Optimax 98RON in the UK), it still pings. That thing needs damn rocket fuel it uses such aggressive timing!!! :banghead:
Cheers,
Ian.
:cheers:
Old Sep 27, 2003 | 11:29 AM
bgood's Avatar
bgood
Cruise-In IV Veteran
St. Jude Contributor
The MMT in the octane boosters is not good for your plugs. You may want to check out your plugs while you are working out the other issues. New plugs may work wonders for you.
Old Sep 27, 2003 | 08:40 PM
FFIN90's Avatar
FFIN90
From: = From Toronto = 9/11/01 FDNY 343 Never Forget
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09-'10-'11-'13-'14
:iagree:
I just got my car back (also a 98) from the shop that went in for a pinging sound, Everyone I talked to said it sounded like engine ping, WRONG :mad . A starter motor and flywheel later the car is fixed, no more knocking or pinging.
[Modified by therefman, 9:40 PM 9/30/2003]
To freekin pinging!!!!!
