I just ordered my 3500 stall today. Its goin to the shop monday to be installed. I also got a B&M tranny cooler goin in also, is there anything else that I should do. It is not a yank, but what kinda stall rpm's should I be getting on average.
I guess it's a "term" thing. It depends on how you define what the original question is.
For example:
(Flash Stall)If you basically are at a complete stop and you smash the pedal (foot off brake)it will "flash" to 3500+.
(Brake Stall)If you have one foot on the brake and one on the gas and you slowly press the gas pedal raising the rpm's....the tires will brake loose at about 2300 rpm's or so.
I guess maybe the question needed to be defined better.
Are you thinking flash?
What does a 3500 flash to?
