The 02-Z is going in for 4.10's/hardened shaft and stage 7 H/D clutch.
Financially I can do the X2 cam 224/228 113 lobe .585 lift at the same time as the rear and clutch.
The question I have is should I hold off on the cam till I do the heads too.
