What Makes Hurst A Short Throw Shifter?
Old Sep 26, 2003 | 04:54 PM
Shylor's Avatar
Shylor
Default What Makes Hurst A Short Throw Shifter?
I have my Hurst ready to install and began thinking, what makes this shifter a shorter throw than my stock shifter? They both are basically rods using a pivot point. Other than the Hurst having a shorter rod what else does it have? Wouldn't just installing the shift **** lower create the same effect as the lower Hurst rod? I really don't get what makes the Hurst better than the stock shifter as they are both very simple in design and only have one moving part, the rod.
Old Sep 26, 2003 | 05:26 PM
Jackal's Avatar
Jackal
Default Re: What Makes Hurst A Short Throw Shifter? (Shylor)
Ill draw it out for you....:)
Therefore a shorter shift.
Old Sep 26, 2003 | 05:39 PM
Patches's Avatar
Patches
I'll photograph it for you. :)
Old Sep 26, 2003 | 06:02 PM
fdxpilot's Avatar
fdxpilot
Higher pivot and shorter stick make for shorter throws. Billet construction vs stamped sheet steel make for solid, accurate shifts and higher quality.
Love mine!! :thumbs:
Old Sep 26, 2003 | 06:11 PM
Shylor's Avatar
Shylor
Default Re: What Makes Hurst A Short Throw Shifter? (fdxpilot)
The pivot point isn't really higher when comparing the two. But I do notice the longer bottom arm.
And what of all this noise others have commented about? When I changed the shifter **** to a solid one I noticed more feedback. So sure you will get transmision sounds through the ****. But I like that. So after I install the Hurst I take it I will experience even more sounds through the solid billet contruction. I'm going to do what others have suggested to dampen it. Hope that works.
[Modified by Shylor, 3:15 PM 9/26/2003]
Old Sep 26, 2003 | 06:40 PM
Jackal's Avatar
Jackal
No noise problems here. Maybee cause of my borla stingers...hmmm.
Old Sep 26, 2003 | 10:30 PM
Admiral Fairway's Avatar
Admiral Fairway
I installed a Hurst a shifter and have not had any noise from it. At the same time I changed the shifter I changed the trans fluid to Royal Purple ATF. The combination of the two really smoothed out the shifting.
Old Sep 26, 2003 | 10:48 PM
jschindler's Avatar
jschindler
The pivot point is higher. You don't see it in the Hurst because of the taller casing around the pivot assembly.
Old Sep 26, 2003 | 11:04 PM
fdxpilot's Avatar
fdxpilot
Default Re: What Makes Hurst A Short Throw Shifter? (jschindler)
:iagree: What he said!!! The difference in throw is something like 3 1/2 vs 5". You'll see when you try it.
Old Sep 27, 2003 | 12:33 AM
MagRed01Atty's Avatar
MagRed01Atty
hey,
i believied the myth that the performance is better and the throw on these after market shifters was significantly less than stocle k too. I installed the one by performance products. same make up and identical looking to the hurst and this is what I found.....It was slightly shorter, 1 inch max, but even the lightest springs (they give you 3 diff) made the slightly shorter throw require so much arm strengh that it made shifting remind me of the curl bar at the gym. i even tried removing springs altogether and effort was acceptable but then the shifter bar lifts up. Remember, the stock is a fully enclosed ball and socket joint, but these hurst etc shifters require a set of springs to hold the ball end of the lower shifter in place. I think its a bad design. adds unecessary restriction/resistence. I got fed up and bought the tap and die, used the published instructions and shortened the stock shift, approx 3 inches and now have the best of both worlds. buttery smoth shift with super short throw and no springs to deal with. :rant:
Old Sep 27, 2003 | 04:00 AM
Shylor's Avatar
Shylor
Default Re: What Makes Hurst A Short Throw Shifter? (Admiral Fairway)
We are talking about 6 speeds correct? So how could a Hurst shifter help an automatic?
Old Sep 27, 2003 | 04:08 AM
lowdowndirty's Avatar
lowdowndirty
It doesn't have to be an automatic to put ATF in the tranny. In fact, I don't know for certain if GM does it, but many maufacturers actually recommend ATF for manuals.
Old Sep 27, 2003 | 09:41 AM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Excellent thread! :cheers: TTT
Tom
Old Sep 27, 2003 | 12:48 PM
fdxpilot's Avatar
fdxpilot
ATF is the standard fill in Borg-Warner/Tremac late model transmissions ( T5 & T56) on GMs and F**ds. Many folks have reported that Synthetic (Mobil 1, Redline, Royal Purple, Amsoil) ATF smoothed out the shift effort. I've only had about 8k on the car since the Hurst install, but it really smoothed out after 1000 mi or so, even on the factory non-synth fill. Hope this helps. :cheers:
[Modified by fdxpilot, 11:50 AM 9/27/2003]
Old Sep 27, 2003 | 04:37 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I just purchased a short throw shifter for the sole reason of having the stick return to the center position from the 5th & 6th position when you pop it out of gear. The stock units spring is TOO WEAK to make the stick return to the center position. Man,,, I hate that.
Bill C
Old Sep 29, 2003 | 01:15 AM
MagRed01Atty
Default Re: What Makes Hurst A Short Throw Shifter? (Bill Curlee)
your springs must be weak. mine return the shift to center strong from 5th and 6th just fine. :steering:
To What Makes Hurst A Short Throw Shifter?
