Oil pressure
Old Sep 29, 2003 | 03:22 PM
DanielJordan's Avatar
DanielJordan
Default Oil pressure
What range does your Oil pressure run?
Old Sep 29, 2003 | 03:42 PM
carpe dm's Avatar
carpe dm
Default Re: Oil pressure (DanielJordan)
50/60 lbs when cold; 40 lbs at normal driving; and sometimes down to 30lbs when really hot and stopped at a light, etc. :yesnod: :)
Old Sep 29, 2003 | 03:46 PM
i_york's Avatar
i_york
Around 50-60psi at idle when cold and around 30psi at idle when hot.
Lowest I've ever seen is 28psi on a hot day with the coolant at around 220f.
Cheers,
Ian.
:cheers:
To Oil pressure
