Relocated MAT sensor - worth it or not?
Old Oct 1, 2003 | 06:58 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Default Relocated MAT sensor - worth it or not?
My only engine mod is a Blackwing. I'm on the fence about the relocated MAT sensor for my 98. Opinions? Will it make any difference?
Old Oct 1, 2003 | 08:12 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
Default Re: Relocated MAT sensor - worth it or not? (SDVette)
Relocated - yes. Relocated/recalibrated - NO. If you can move the stock sensor further out away from the engine heat, you will see a couple hp. If you fall prey to the "recalibrated" thing that some sell, you will not see a change - I lost hp after adding mine (dyno confirmed).
Old Oct 1, 2003 | 08:24 PM
geekracer's Avatar
geekracer
Default Re: Relocated MAT sensor - worth it or not? (BSiegPaint)
:iagree: The recalibrated MAT sensor was a hack whose time has long gone.
To Relocated MAT sensor - worth it or not?
