? Gear Change require Speedo Re-Calibration ?
Oct 2, 2003 | 12:44 PM
St. Jude Donor '03-'04-'05
Read a thread relating to gear change-out. Does a differential swap require a re-calibration of the speedo? If so, can this be done through LS1 edit? Thanks
:hat
Oct 2, 2003 | 01:59 PM
Cruise-In V Veteran
St. Jude Contributor
Re: ? Gear Change require Speedo Re-Calibration ? (Mviola)
Not sure on the A4...The answer is NO on the M6.
Oct 2, 2003 | 02:01 PM
LS1Edit Guru
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
NO change required on either for the SPEEDO. However, on the A4, you will need some reprogramming for shift points, etc..
Oct 2, 2003 | 03:11 PM
Re: ? Gear Change require Speedo Re-Calibration ? (nevrenuf)
:iagree: If he says so....you better DO IT! :lol: :thumbs: he knows his shiat!
[Modified by IMQUIK, 3:11 PM 10/2/2003]
Oct 2, 2003 | 05:47 PM
Re: ? Gear Change require Speedo Re-Calibration ? (C5 StockSwap)
No; and this is unique to C5 Corvettes.
Oct 2, 2003 | 06:45 PM
(nevernuf) Just curious but what about LS-1 edit for rear wheel diameter and I assume that would apply to both transmissions?
Oct 2, 2003 | 08:13 PM
Re: ? Gear Change require Speedo Re-Calibration ? (Sack Rat TT)
rear tire heigth changes will affect the speedo. LS1 Edit and others allow you to change these parameters.
Oct 3, 2003 | 12:41 AM
Re: ? Gear Change require Speedo Re-Calibration ? (Mike Mercury)
Thanks everyone! Speed-Sensitive Shift points have been taken care of through LS1 Edit. The A4 is running like like a gyro :yesnod:
adjustment ,
automatic ,
c6 ,
calibrate ,
calibration ,
corvette ,
gear ,
ls1 ,
speedo ,
speedometer ,
swap
