Check Engine- throwing Codes and more
Old Oct 3, 2003 | 09:41 AM
Mehfoud's Avatar
Mehfoud
Default Check Engine- throwing Codes and more
Nice wake up call this morning driving to work - Check Engine. Luckly I was only 1 mile away from home, went back and wrote down the codes and took the Escort to work (daily beater).
Anyway
10 PCM P0442 H C - I guess this means the gas cap is loose, will check it when I get home?
58 SDM B1001 H - Don't know what this is, maybe the airbag
A0-LDCM - Left Door Control Module
B2252 Key Cylinder Switch Fault
B2282 Battery #1 Fault
B2284 Battery #2 Fault
Interesting. Still thinking FOB
A1 RDCM Right Door Control Module
B2203 Right Window Up Switch Fault
B2283 Battery #1 Fault
B2285 Battery #2 Fault
Interesting, but the Right window works fine.
B0-RFA - Remote Function Actuation
· U1016 Loss of Communication with PCM
· U1064 Loss of Communication with BCM
· U1096 Loss of Communication with IPC
I guess this means the battery in the FOB is going bad? I have had to reset it a few times.
Overall, it looks like a loose gas cap, and fault FOB and something is wrong with the airbag.
Any help would be appreciated, trying to make a road trip this weekend.
:cheers:
Old Oct 3, 2003 | 04:07 PM
Chopper Larry's Avatar
Chopper Larry
Default Re: Check Engine- throwing Codes and more (Mehfoud)
What is the possibility that the battery leaked, or that the A/C drain overflowed into the area where the BCM & PCM are?
This has happened to many, and the symptoms are similar. Ya end up replacing the BCM & PCM.
Old Oct 3, 2003 | 07:44 PM
Mehfoud's Avatar
Mehfoud
Default Re: Check Engine- throwing Codes and more (Chopper Larry)
I pulled the battery and everything looks fine. Anybody have any information on thie A/C overflow idea? Any other ideas? I just took the car out and it runs great (except for the check engine light).
Anybody?
Gas cap is on just fine
Another code appears 28 TCS C1255
Something going on with my Handling System.
Going to take her out for a spin and I am bringing the running shoes!
[Modified by Mehfoud, 6:54 PM 10/3/2003]
[Modified by Mehfoud, 6:57 PM 10/3/2003]
Old Oct 3, 2003 | 09:02 PM
Mehfoud's Avatar
Mehfoud
Cleared all the codes and took her for a spin. All that is left is the is
Check engine light is not longer lighting up
Looks like I some new batteries in the FOB.
Thanks for the recommendations Larry
:cheers:
Old Oct 6, 2003 | 10:14 AM
Chopper Larry
:cheers:
I only mention this because, a friend has a '98 Pace Car, and the battery leaked and ruined the BCM & PCM. I've heard the A/C drain getting clogged up and overflowing into that area also does the same thing. Good luck, and let us know what you find out.
To Check Engine- throwing Codes and more
