Piston slap help
Old Oct 3, 2003 | 06:41 PM
WolfeBros's Avatar
WolfeBros
St. Jude Donor '05-'06-'10-'11
Default Piston slap help
Anyone have a piston slap problem while in warranty and wondering what the outcome was? I sure would appreciate any input before I take on the dealer. Mine is a 2002 coupe with 4,400 miles.
[Modified by WolfeBros, 11:42 PM 10/3/2003]
Old Oct 6, 2003 | 04:03 PM
98CFive's Avatar
98CFive
Default Re: Piston slap help (VetteDrmr)
I believe you are right about the pinging rather than piston slap. After finding carbon in the cylinder it makes more sense. Carbon deposits get hot and tend to glow in the chamber, causing pre-ignition(pinging). Cleaning with the GM solvent removes the carbon and --------------no more pinging, for a while. Take it up to 6000 rpm once in a while(3-5) days a week!!!!!!!
:steering:
Old Oct 6, 2003 | 05:47 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: Piston slap help (98CFive)
98
QUOTE" believe you are right about the pinging rather than piston slap. After finding carbon in the cylinder it makes more sense. Carbon deposits get hot and tend to glow in the chamber, causing pre-ignition(pinging). Cleaning with the GM solvent removes the carbon and --------------no more pinging, for a while. Take it up to 6000 rpm once in a while(3-5) days a week!!!!!!!
Whoooooooooo,,,,,,60000 rpm once in a while(3-5) days a week!!!!!!! Man, mine must be like BRAND NEW inside!! :D :D :thumbs: I do that 3-5 times a day all week! :lol:
Bill C
Old Oct 6, 2003 | 06:45 PM
wwashing's Avatar
wwashing
Default Re: Piston slap help (Bill Curlee)
98
Bill C
There is an obvious difference between the sounds of a piston slapping and pre-ignition (pinging).
The piston slap is a knocking sound, like someone is inside pounding the cylinder walls with a hammer.
Pre-ignition is a lighter, rattling sound; Like pebbles rattling around in a pipe or in a tin can. :cheers:
Old Oct 6, 2003 | 06:51 PM
WolfeBros's Avatar
WolfeBros
Default Re: Piston slap help (wwashing)
:iagree: Two different problems with two different sounds. What is ironic is that the piston slap sounds worse but actually causes no real damage while a pinging, or predetonation can cause serious damage if it goes on without check.
Old Oct 6, 2003 | 07:18 PM
Cirrus8's Avatar
Cirrus8
Default Re: Piston slap help (WolfeBros)
My Vette has a tic, tic. tic sound only when it is first started and is warm. A few blips of the throttle and it goes away. I have talked to a couple of service writers and they say it is injector noise!!! It does not make any noise when it is started cold. Who knows what the Shadow knows. :D :D
Old Oct 6, 2003 | 08:02 PM
angstr1's Avatar
angstr1
I have 21,000 on my 2002. I ran two bottles of the GM top end cleaner and the slap noise disappeared. 2,000 miles later, its baaack. Guess the gent who recommended buying a case of the GM cleaner was right. However, instead of paying $13 a bottle, you can buy an alternative brand (i.e. Chevron, Slick 50, etc.) that does the same thing at Walmart for $5. I understand the dealer won't tear down an engine to fix this problem because "its normal." I heard that GM engineers have since begun "coating" pistons to take care of the noise on 2003's. Guess I'm stuck with a $40K tractor.....well, at least its fast. :mad
Old Oct 7, 2003 | 11:30 AM
Heretic's Avatar
Heretic
Default Re: Piston slap help (angstr1)
The evap purge soleniod on my 98 LS1 Camaro would tick just like a lifter when the engine was cold.
Try unplugging the EVAP soleniod when the engine is ticking and see if it goes away.
Old Oct 7, 2003 | 06:39 PM
7thgeneration's Avatar
7thgeneration
Default Re: Piston slap help (Heretic)
I was wondering if anyone has tried to correct the piston slap problem with a thicker film synthetic such as amsoil, or royal purple ? From what I understand about the problem this may help. As far as carbon build up goes would a hotter spark plug help in burning the fuel more completely ? And thus reduce carbon ? Just my .02 Nick :seeya
Old Oct 7, 2003 | 08:35 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
... Someone advised me that the slap I was hearing with the 02 was the result of carbon build-up and recommended running a couple of tanks of gas through with GM part #12345515 in each tank
Isn't that detonation (a.k.a. pinging)? I thought piston slap was actually the skirts of the piston contacting the cylinder walls when the engine was cold and the tolerances were larger. Then, as the pistons & cylinder walls warm up, the tolerances go down and the slap goes away. Don't see how carboning up a cylinder can cause piston slap.
Or, am I wrong?
Have a good one,
Mike
There is alot of confusion here...The two most common cold start noises are caused by "piston slap" or "carbon knock".Piston slap is simply caused by the piston rocking in the bore caused by the "short skirt" design of the piston.As the piston expands with temperature,the noise goes away.
Carbon knock is caused by carbon deposits being compressed between the piston and cylinder head,or between the back of a valve and the cylinder head.Carbon deposits are hard as a rock,and as the engine warms the carbon becomes softer resulting in the noise going away.Both noises are similar and often misdiagnosed.Carbon knock will generally be louder.
Short of major surgery,nothing in a bottle will eliminate piston slap.Carbon knock can be eliminated with the decarbon procedure,or prevented with Techron in the tank as preventitive maintanance :thumbs:
Old Oct 8, 2003 | 10:36 AM
angstr1's Avatar
angstr1
Default Re: Piston slap help (C-5 TECH)
... There is alot of confusion here...The two most common cold start noises are caused by "piston slap" or "carbon knock".Piston slap is simply caused by the piston rocking in the bore caused by the "short skirt" design of the piston.As the piston expands with temperature,the noise goes away.
Soooo, I guess the GM engineers goofed in designing the pistons. :chevy I think GM could do better by righting this wrong under warranty. After all, we shouldn't have to live with this annoying noise, especially given the price tag on the best American sports car built. My dealer says piston slap does not cause any wear and tear on the engine. I don't believe this, do you? Seems to me that a rocking piston would eventually cause damage to the cylinder bore. Its a mystery to me why some engines experience this noise sooner than others. Mine didn't start making this noise until around 12,000 miles. Honestly speaking, the startup noise appeared to go away for a while after running two bottles of the magic GM juice through the fuel system. I do know the difference between a knock and ping sound. At startup (idle), my engine makes a clacking sound (noise is similar to perhaps a loose, rocker arm). I can't imagine an engine pinging that loud at idle. Are there any GM technicians in this forum who can provide the ground truth on this issue? Will piston slap cause wear and tear on my engine? Will GM replace the pistons (with the new and improved ones) if we bark loud enough? :confused:
Old Oct 8, 2003 | 10:58 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
When I stated carbon knock,I was not refering to pinging.Carbon knock is a noise simular to piston slap,caused by the piston or valve trying to compress the carbon deposits.
The C5 uses a piston design that is also used in many high performance engines and race engines.Though the piston noise is annoying and I agree,it is the nature of the beast.
GM has determined the the piston slap is not a durability issue,but they coated the pistons in 2002 to allow for a tighter fitting piston to address this issue.
To Piston slap help
