help removing front calipers
Old Oct 3, 2003 | 11:27 PM
highpressuremax's Avatar
highpressuremax
Default help removing front calipers
the two bolts to remove the front caliper keeps spinning, and to bolts wont come out, what am i doing wrong? :banghead: :confused: :withstupid:
Old Oct 3, 2003 | 11:30 PM
Sam Lin's Avatar
Sam Lin
Default Re: help removing front calipers (highpressuremax)
The round thing they screw into on the other side of the caliper flange has 2 flats that you have to hold with a wrench.
Sam
Old Oct 3, 2003 | 11:43 PM
Richin Chicago's Avatar
Richin Chicago
Put a 16 mm on the round nut that is spinning. There are actually 2 flats on the round nut. When you get those bolts out pull the round nuts out along whith rubber boot they fasten to. Grease the pins with a high temperature grease designed for disc brake caliper pins. (Napa has the grease) and put back in place. You should do this everytime you change pads as this is the "float" part of the calipers. If these pins become corroded you will have a very short pad life and very hot rotors as the pads will drag.
To help removing front calipers
