Need help headlight problem
Old Oct 9, 2003 | 05:54 PM
hot4u's Avatar
hot4u
Default Need help headlight problem
Fog lights don't work and headlights flip up when I turn on parking lights,also motor on driver side headlight runs about 15 seconds after headlights are down
Old Oct 9, 2003 | 06:28 PM
Cajun99's Avatar
Cajun99
Default Re: Need help headlight problem (hot4u)
I don't have a clue but I'm gonna :lurk: and see what comes up in case this :crazy: :crazy: happens to mine. :cheers:
Old Oct 9, 2003 | 06:32 PM
highpressuremax's Avatar
highpressuremax
sounds like you have a stripped plastic gear on the headlight motor, I just replaced mine, I bought a brass gear from eckler's $ 49.99 (rebuild kit) 1 to 2 hours to fix, you have to remove the whole headlight to get at the gear, not to hard to do. directions come with the gear. that will also solve your problems with your fog lights and headlight flip. :auto: :steering:
Old Oct 11, 2003 | 07:50 PM
hot4u's Avatar
hot4u
Default Re: Need help headlight problem (highpressuremax)
Thanks fixed the fog light problem(replaced bulbs)now just have the headlight motor that keeps runing after the headlights are down, and can not get the headlights to stay down when turning on the parking lights will try the kit from eckler'
To Need help headlight problem
