Problem With Lights
Old Oct 9, 2003 | 07:59 PM
sunking's Avatar
sunking
Default Problem With Lights
i own a 1997 c5...i have had the occasional problem where when you turn on the headlights they light but don't come up...turn them off and back on and they come up fine...
driving home tonight it happened again but this time it was slightly different...when i turned on the lights, they lit in the hood but did not come up...also, the dash lights and the tail lights did not turn on as they should...the brake and turn signal lights worked fine...the running lights came on but i could not get the fog lights to come on...the cruise control also would not work (also on the stick with the lights)...had to drive home in the dark with just the running lights...not too much fun...
any ideas...
thanx in advance...
sunking
Old Oct 9, 2003 | 08:20 PM
Admiral Fairway's Avatar
Admiral Fairway
Default Re: Problem With Lights (sunking)
Could be a problem with the turn signal assembly, everything goes thru it. I just had to have mine replaced because the turn signal where acting wierd.
Old Oct 10, 2003 | 01:23 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: Problem With Lights (Admiral Fairway)
:iagree:
Thats what I would check!
Old Oct 11, 2003 | 05:19 PM
sunking's Avatar
sunking
Default Re: Problem With Lights (Bill Curlee)
left the vette home with the wife yesterday due to the problem with the lights...she needed to go somewhere in the afternoon and knew of the problem and tried the lights...the lights came up!!!! but the dash and the tail lights did not come on...when she got where she was going she turned the lights off and while the headlights went out they stayed up...i turned them down using the dials in the engine compartment when i got home from work...
i have played with it a little more today...when i first went out to look at it, when i turned on the lights the lights came right up...turning them off left them open...i turned them down again and now if i turn them back on they do not open up...the turn signals work but i cannot turn on cruise or the fog lights and the tail lights continue to not go on...the daytime running lights do come on and stay on...
i checked the dtc codes and there is nothing there (except for a tire pressure problem that i have had for some time with the right rear wheel)...
i went thru the fuses and cannont find a single fuse that would cause all of this to happen if it went bad...
so....
anyone heard of this kind of issue...could this be the stick causing problems like these??? if it is the stick, anyone care to guess what it might cost to get it replace/fixed???
again, thanx for any suggestions/advice....
sunking
Old Oct 11, 2003 | 07:14 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Are you going to attempt to repair thr problem your self?
If you are, I will look in the repair manual and see what you need to accomplish the task, I had my wiper assembly out and it was EASY to dis assemble the column covers and the wiper module. All you basicaly need is an inexpensive set of torx's screw drivers. Most auto parts stores sell them as a set for around $5. Sears has a GOOD set for $20.
The switch is a dealer item and I would hate to guess how much it is. Probably around $35.
Please let us know if you want to repair it your self and I will give you pointers.
GO FOR IT!!!
Bill Curlee
Old Oct 11, 2003 | 08:07 PM
Admiral Fairway
The switch assembly is $213.71 from the dealer, trust me this is not a guess.
To Problem With Lights
