The throttelbody have the same size all years (97-04). The MAF size changed -01 so a -01 airbridge/coupler only fit 01-04 cars.
If you put a -01 or later MAF in a 97-00 car you will need,
- a -01 or later airbridge/coupler
- a -01 or later airfilter
- a adapter cable between the stock 97-00 IAT and MAF cable to the new MAF. The reason is that the -01 and later MAF have a 5-pin connector and have the IAT sensor built in to the MAF.
