Is this safe??
Old Oct 11, 2003 | 10:40 AM
NotaZ06's Avatar
NotaZ06
Default Is this safe??
To run zo6 size tires on y2k,s ? I found a very cheap set and there is a big event 2morro and my runcraps are bald. TIA :cheers:
Old Oct 11, 2003 | 12:57 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: Is this safe?? (NotaZ06)
I have the same question, SORT OF! Hope someone chimes in! I want to run ZO6 rims on STOCK 98 tires!
BC
Old Oct 11, 2003 | 01:07 PM
NoMoHonda2's Avatar
NoMoHonda2
kyle, do you know anything about pcm module? Im trying to hook up my air to fuel
Old Oct 11, 2003 | 09:31 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default Re: Is this safe?? (NoMoHonda2)
You can run the Z06 tires on the C5 rims. Thay will fit just fine. I have 295's on my rears. I am sure the 98 tires will fit on Z06 rims but it might look odd. kaley
Old Oct 12, 2003 | 04:27 AM
dmc80868's Avatar
dmc80868
I have a 2000 and am running 265/45/17 in the front and 295/40/18 on the stock rims with no problems for 6 months now. Might be differnet for you if your car is lowered. Mine is not.
To Is this safe??
