I need help bad
Old Oct 12, 2003 | 08:09 PM
peffy117's Avatar
peffy117
8th Gear
Default I need help bad
Ok i was looking at carteks website, if i bought this engine what else would i need to get and how much would that cost me? and is this a complete engine don't need more engine parts? also what kind of horsepower and 1/4 0-60 times can this get me?
CARTEK IRON BLOCK 421 CID LS1-LQ4 LONG BLOCK
Lunati 4340 pro series crankshaft 4.125" stroke
Scat 4340 connecting rods
JE custom forged pistons
Plasma moly rings set
Clevite H series race bearings
Rotating assembly fully balanced
Engine blueprinted
Cartek hyd. roller cam
Double roller adjustable timing chain
Cartek stage 4 LS1 heads
Fully assembled long block (LQ4 cast iron engine and heads core required)
Old Oct 12, 2003 | 08:15 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: I need help bad (peffy117)
I can tell you right now you will need a HD clutch assembly and hardened output shafts in your diff carrier... :yesnod:
VR :cheers:
Old Oct 12, 2003 | 08:32 PM
kumar75150's Avatar
kumar75150
Default Re: I need help bad (vetterdstr)
You will need to pay for a 6.0 block.
I am assuming you have stock heads.
To I need help bad
