Diff. Leak....what should I expect....?
Old Oct 14, 2003 | 06:49 AM
blittle's Avatar
blittle
Default Diff. Leak....what should I expect....?
Off to see the Vette Doctor on Thursday.........got the common diff leak.....anybody know what the common repair is and the going price? :sad:
Old Oct 14, 2003 | 07:27 AM
Mr. Jones's Avatar
Mr. Jones
Default Re: Diff. Leak....what should I expect....? (blittle)
i am having the gears changed so I don't know whats involved with a leak fix only. make sure they use the new seals #89047953 side cover and 88996703 output shaft oil seal. these are new parts from GM, the dealer didn't even have the output shaft seal in there system yet.
my car started to leak at 5900mi
Old Oct 14, 2003 | 04:42 PM
bellomo's Avatar
bellomo
Don't expect anything from GM if not under warranty even though it is a known problem on many of the C'5s. I have a 99 with only 9500 miles on it outside of warranty and it cost me $600 for the repair after another delaer quoted me $1200. Shop around and find a reputable shop. Also ask them to check out the TSB out on this subject, it list the seals posted above.
Old Oct 14, 2003 | 05:53 PM
blittle's Avatar
blittle
Default Re: Diff. Leak....what should I expect....? (bellomo)
Ouch......but that's pretty much what I was expecting! Thanks..... :(
Old Oct 14, 2003 | 06:49 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Info - Release of New Rear Axle Seals #03-04-20-005 - (09/12/2003)
1997-2004 Chevrolet Corvette
This bulletin is being issued to inform dealers that new and improved rear seals have been released for service for the above listed vehicles.
Use the new output shaft oil seal, P/N 88996703, and the new differential side cover O-ring, P/N 89047953, when repairing rear axle leaks.
Parts Information
Part Number
Description
88996703
Seal, Output Shaft Oil
89047953
O-ring, Differential Side Cover
Old Oct 14, 2003 | 06:59 PM
Neil Baker's Avatar
Neil Baker
Just had my 2002 with 14000 miles back to the dealer for rear leak. They replaced right and left covers and gaskets. No leaks now. :flag
Old Oct 15, 2003 | 03:29 PM
blittle's Avatar
blittle
Default Re: Diff. Leak....what should I expect....? (C-5 TECH)
Parts Information
Part Number
Description
88996703
89047953
Thanks C5tech! I don't want to pay the bucks but I don't like the leak either! :seeya
Old Oct 15, 2003 | 07:49 PM
irfgt's Avatar
irfgt
This repair can easily be accomplished in two hours or less X the shop labor rate. I will be happy to do side cover leaks for $600.00. I could do at least 4 per day. :party:
Old Oct 16, 2003 | 12:23 PM
blittle's Avatar
blittle
Default Re: Diff. Leak....what should I expect....? (irfgt)
Well.......the dealer ordered the parts as per the latest TSB and said the bill will be $450.00 installed. Could have been worse I guess..... :crazy:
Old Oct 18, 2003 | 08:48 PM
SQEZN BI's Avatar
SQEZN BI
Expect to add oil at some point. :D
Old Oct 18, 2003 | 11:28 PM
blittle's Avatar
blittle
Default Re: Diff. Leak....what should I expect....? (SQEZN BI)
In other words.....it really is not going to be any better than before the fix?
Old Oct 19, 2003 | 12:12 AM
Should cost a couple of hours labor plus parts. Had mine done twice and I know they didn't spend any more time than that on the repair.
To Diff. Leak....what should I expect....?
