Decarbonization - Super Smokes
Old Oct 15, 2003 | 03:24 AM
shaheen's Avatar
shaheen
Default Decarbonization - Super Smokes
I had the pings, so I took everyone’s advise and used two cans of GM Top Engine Cleaner through the PVC inlet with the car running…. Let it sit for 12 hours and fired her up. Wow... The car completely disappeared in a cloud of smoke for about 3 minutes. Couldn’t even see the end of the hood. The car seems to be running much better now, but I still get some very slight pinging (It is about 80% better). Maybe it needs another can or two?
From all the stories, I expected my oil to be very dirty, but when pulling the dipstick after 10 miles of driving, the oil appears very clean (Almost Clear). Do you think I still need to change it?
[Modified by shaheen, 12:24 AM 10/15/2003]
Old Oct 15, 2003 | 11:21 AM
carpe dm's Avatar
carpe dm
Default Re: Decarbonization - Super Smokes (shaheen)
It might, but it could also be a timing issue, bad gas, dirty wires on the MAF, etc. :rolleyes:
Old Oct 15, 2003 | 11:37 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: Decarbonization - Super Smokes (carpe dm)
Definitely change the oil after a decarb procedure. Much of it leaks down and mixes with the oil and thins it out, which is why it seems clear looking.
Old Oct 15, 2003 | 12:59 PM
RskyBns's Avatar
RskyBns
Ahhh....nothin like smokin' out your neighbors with a decarb :D
Old Oct 15, 2003 | 01:16 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: Decarbonization - Super Smokes (RskyBns)
:skep: :skep: :sad: :lol: :lol: :cheers:
Old Oct 15, 2003 | 04:59 PM
johnnyvettes's Avatar
johnnyvettes
CHICAGO CREW !
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
Default Re: Decarbonization - Super Smokes (LittleBoyBlu99)
sounds like fun ! :yesnod: :thumbs:
Old Oct 15, 2003 | 06:35 PM
VetteDrmr's Avatar
VetteDrmr
.. The car seems to be running much better now, but I still get some very slight pinging (It is about 80% better). Maybe it needs another can or two?
I've found that it takes a while for the decarboning function to complete. Run a full tank of gas through her and see how the pinging is handling. Also, you might have a stuck knock sensor (there's a link around here somewhere that describes the problem) and the computer isn't pulling any timing at all.
HTH, and have a good one,
Mike
Old Oct 15, 2003 | 11:33 PM
MattG's Avatar
MattG
Default Re: Decarbonization - Super Smokes (VetteDrmr)
If the pinging doesnt go away, check your fuel pressure.. Make sure it isnt falling at higher RPMs which would mean a fuel pump heading south.
To Decarbonization - Super Smokes
