Remote door lock keychain programming
Old Oct 15, 2003 | 05:35 PM
jhhaas's Avatar
jhhaas
Cruising
Default Remote door lock keychain programming
Is there a simple way to reprogram the door lock/unlock on the keychain? My battery was dead for quite some time and now the buttons on the keychain do nothing. Does this mean a trip to the dealer? Sorry if this is a RTFM problem, the manual is in the car in the shop.
Old Oct 15, 2003 | 05:50 PM
BlackC5Vette's Avatar
BlackC5Vette
Default Re: Remote door lock keychain programming (jhhaas)
You can try holding the lock and unlock buttons on the fob for 10 seconds (you'll hear the horn when its done) and see if that worls. If not you might have to reprogram it through the DIC. Do a search and you should find good instructions. :D
[Modified by BlackC5Vette, 4:51 PM 10/15/2003]
Old Oct 15, 2003 | 06:14 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: Remote door lock keychain programming (BlackC5Vette)
Your Corvette Owners manual has a very good write up and instructions on it. Look under KEY FOB Training in the back of the manual in the index. You will be able to program up to three FOBS. You must also program all of your FOB at the same time. There is also a re-Sync function but, you have to Train before you can Sync. Once you train the FOBs if they dont work for some reason, you can press and hold the LOCK & UNLOCK buttons at the same time for approx. 45 sec (horn will beep when sync operation is complete).
Please let us know if you have any problems and let us know if you were successful.
BC :thumbs:
[Modified by Bill Curlee, 5:15 PM 10/15/2003]
Old Oct 15, 2003 | 07:26 PM
jhhaas's Avatar
jhhaas
Cruising
Default Re: Remote door lock keychain programming (Bill Curlee)
Thanks for the info. Hopefully, as my knowledge of these cars grows, I will be able to return the favor for some other forum member.
To Remote door lock keychain programming
