Amsoil users check in....
Oct 15, 2003 | 10:17 PM
http://www.syntheticwarehouse.com/drivetrain_lubes.htm
I going to to change my transmission and gear oil soon....i found the product i want but not sure which to buy for which.
Transmission = 100% Synthetic Universal Automatic Transmission Fluid ?
Gear = Synthetic Gear Lube ( 75w-90 ) ?
Thanks!
Oct 15, 2003 | 10:35 PM
Re: Amsoil users check in.... (00c5coupe)
Gear = Synthetic Gear Lube ( 75w-90 ) Series 2000
:iagree: This is what you need. Will work great. :thumbs:
Oct 15, 2003 | 10:40 PM
Re: Amsoil users check in.... (IMQUIK)
Amsoil in the engine and tranny here. Not in the gearbox though. :p: Tom. :jester
Oct 15, 2003 | 10:49 PM
Re: Amsoil users check in.... (Patches)
:nono: Because he is chicken. :p: It's worth .895 HP. :lol: :lol:
Oct 15, 2003 | 11:14 PM
do i need to add Limited Slip Axle Lube Additive
Oct 16, 2003 | 06:06 AM
For the rear, you need the Series 2000 75W-90. For the tranny, the ATF. You do not need the additive with the Series 2000 75W-90, and adding it will reduce or eliminate your limited slip capability.
Once you change them out, drive the car easy to a parking lot and do 10 slow figure 8's with the car. Then take it easy for a few hundred miles to make sure the new oil has worked into the clutch packs.
I am running both these products in my car and have been very happy with the results.
[Modified by vettenuts, 6:06 AM 10/16/2003]
Oct 16, 2003 | 08:02 AM
Re: Amsoil users check in.... (vettenuts)
AMSOIL in engine crankcase & rear..:yesnod:
But NOT in tranny... Using GM fluid there.
Weren't people saying it could be TOO slipperly for A4's??????
Anyway, that set up is what works for me! :smash:
Oct 16, 2003 | 01:46 PM
Re: Amsoil users check in.... (indypace78)
:nono: No problems with it in my A4! :D Runs cooler.
Oct 16, 2003 | 02:49 PM
Um, probably this has been posted somewhere, but how much fluid does the MT6 takes ? How about the rear diff ? Thanks.
Oct 16, 2003 | 04:37 PM
Re: Amsoil users check in.... (Wah)
Oct 16, 2003 | 04:46 PM
Re: Amsoil users check in.... (gmblack3)
Amsoil in the engine only so far. Will get to the rest eventually! :thumbs:
