11:1 compression and 92 octane?
Old Oct 16, 2003 | 08:59 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Default 11:1 compression and 92 octane?
Thanks to western Missouri's wonderful fuel ratings, 92 octane is the highest pump gas I can get. Now if I'm running the Patriot Stage 2 LQ9 (ls6 style) heads, am I going to see any problems with 92 octane? Or should I just tune it and drive the hell out of it?
Thanks.
Old Oct 16, 2003 | 10:00 AM
marco383's Avatar
marco383
Default Re: 11:1 compression and 92 octane? (JoeyG)
A number of other variables influence detonation (weather, cam timing, etc.), but I'm running 11.1:1 without audible detonation on 93 octane. One little ole octane number shouldn't make much of a difference.
Old Oct 16, 2003 | 10:23 AM
Trevor @ Texas Speed's Avatar
Premium Supporting Vendor
As mentioned, there are a few factors that will influence detonation, but tuning will be a big factor. I ran 11.1:1 compression ratio with my heads/cam setup and 92 octane pump gas with no problems. When the heat of the summer rolls around, I will normally pull a few more degrees of timing out.
Let us know if you have any questions on the Patriot stage II LS6 cylinder heads. We've been selling them like crazy! :crazy:
Trevor
Texas Speed & Performance
806-866-0734
[Modified by Trevor @ Texas Speed, 3:24 PM 10/16/2003]
Old Oct 16, 2003 | 12:07 PM
JoeyG's Avatar
JoeyG
Default Re: 11:1 compression and 92 octane? (Trevor @ Texas Speed)
Brian just sold me a set :cheers:
Old Oct 16, 2003 | 12:58 PM
SpinMonster's Avatar
SpinMonster
What cam are you running as LSA is one of the biggest variables. If you have a big cam with a 112 or lower LSA you could probably get away with big 11's with no issue. I run 11.6:1 on 93 with no issues and i know of some tuners having seen over 12:1 on 93. The compression ration is related to 2 variables, static and dynamic compression. One more thing, the ls1/6 pcm's adjust automatically for hot weather tuning.
Old Oct 16, 2003 | 01:25 PM
JoeyG's Avatar
JoeyG
Default Re: 11:1 compression and 92 octane? (SpinMonster)
MTI C2 224/224 .581/.581 112
Yeah, I know baby cam :steering:
Old Oct 16, 2003 | 01:43 PM
go_mer's Avatar
go_mer
I'm running the patriot LS6 style heads with the 59cc chambers and I haven't had any trouble at all running 93 in it. I've autotapped the car and it isn't getting any KR.
Old Oct 16, 2003 | 02:01 PM
SpinMonster
Actually it is an awesome cam....yes not the biggest but it is a great street cam that makes a lot of power for its size. Lots of guys have gotten over 420rwhp with bolt-ons with it. I would bet you could run 11.5:1 on 92 with that cam.
Old Oct 16, 2003 | 06:55 PM
SFVetteman's Avatar
SFVetteman
If yours is a baby cam then my cam must be premature :D Here in California there are many C5's running around with a similar 224 cam and 11:1 compression on 91 octane with no problem.
Old Oct 16, 2003 | 08:20 PM
JoeyG's Avatar
JoeyG
Default Re: 11:1 compression and 92 octane? (SFVetteman)
Yeah, I know baby cam :steering: If yours is a baby cam then my cam must be premature :D Here in California there are many C5's running around with a similar 224 cam and 11:1 compression on 91 octane with no problem.
Well originally I wanted to do a 230/236 .575/.575 110, but I'm going to be happy with what I've got. :yesnod:
To 11:1 compression and 92 octane?
