Which Plug Wires for Headers?
Old Oct 17, 2003 | 01:03 AM
DocSandy's Avatar
DocSandy
From: When I say who is the mastah you gotsta say Shonuf
Default Which Plug Wires for Headers?
What's the best plug wire set to resist the heat from headers?
Old Oct 17, 2003 | 01:41 AM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Re: Which Plug Wires for Headers? (DocSandy)
I don't know if brand makes a diff or not. I put on 9mm.
:cheers:
Old Oct 17, 2003 | 01:47 AM
boblackhardtop's Avatar
boblackhardtop
Taylor got a 10.5mm :eek:
Old Oct 17, 2003 | 05:15 AM
blktie8's Avatar
blktie8
Talk to Steve http://www.magnecor.com
Old Oct 17, 2003 | 06:51 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I run MSD's with "Cool Socks" (special insulated covers) ...
VR :cheers:
Old Oct 17, 2003 | 07:13 AM
Patches's Avatar
Patches
I run Taylor 10.4mm Thundervolt wires with Taylor 1200 deg. F Fire
Sleeves. I had mMagnecors at first but their boot is exactly like stock and a few were touching the primaries. That's the main reason I switched to the Taylors - their boot is smaller and shaped differently and easily clears the primaries.
Old Oct 17, 2003 | 09:39 AM
XTrooper's Avatar
XTrooper
I like the Accel Extreme 9000s with integrated heat shields for use with headers. :yesnod:
Old Oct 17, 2003 | 10:28 AM
MTWallet's Avatar
MTWallet
Default Re: Which Plug Wires for Headers? (XTrooper)
Yes, the brand DOES make a difference. Some wires have longer & wider shields on the plug end which can touch the headers. I run the Taylor Spiro-Pro 8.5mm and they have the smaller tear-drop style ends that don't touch my headers at all, even on the dreaded #7 cylinder. There is no need to use heat socks with these wires either.
Old Oct 17, 2003 | 04:20 PM
speedjohnson's Avatar
speedjohnson
Default Re: Which Plug Wires for Headers? (MTWallet)
The cool socks are really a great way to go. Sometimes they are'nt long enough to shield the wire up high enough...If that's the case, Aeroquip makes a silicon/nomex heat shield tube in various sizes...it's silver in color and has a fuzzy nomex lining... -10 or -12 outa be about right for a spark plug wire and boot. You can lay these right on the header without much consequence... sj
Old Oct 17, 2003 | 04:59 PM
NavyC5's Avatar
NavyC5
CI 3-4-5-6-10 Veteran
St. Jude Donor '03-'06-'08-'09-'10
I actually had one of my Taylors touch my headers and melt through. I switched to the MSD wires. Nice thing about the MSD's is there boots bend. So you can keep them away from the headers. :yesnod:
Old Oct 17, 2003 | 07:32 PM
7LitreC5's Avatar
7LitreC5
I am running stock wires with cool sox. So far they've been fine for a year.
Old Apr 14, 2020 | 12:26 PM
Dirty Harry's Avatar
Dirty Harry
From: Texas, Republic of Texas/ Founding Member NDCC
I'm convinced there is no such set of plug wires. I have gone through 3 sets of Taylor 10.5 mm and now on a set of MSG 10.5 mm and none of them will work on #7 AND on this set of MSG's I have a set of 2400 deg fiberglass boots with a 1200 deg. sleeve on top of it!! I give up!! Oh, my headers are those crappy LG headers!! I also failed to mention mine is heads , cam and supercharged!
Old Apr 14, 2020 | 12:55 PM
Supercharged111's Avatar
Supercharged111
I have GMPP wires with stock heat shields and TSP 1 3/4" long tubes, the older coated mild steel ones. Zero issues.
Old Apr 14, 2020 | 01:12 PM
oharal's Avatar
oharal
Sure I'll jump into a nearly 17 year old necrothread lol. My Duralast Golds are still kicking fine nearly 5 years and 50k later with Kooks 1 7/8 LTs...
To Which Plug Wires for Headers?
