belt squel?
Old Oct 18, 2003 | 09:00 AM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Default belt squel?
I have a squeling sound coming from what seems to be the drive belt when I accelerate. It does not do it at idle but when I am rolling it gets steadily louder as I increase pedal pressure.
Why would it only happen when I am moving if it was the belt?
Could it be the idler pulley?
Has anyone had this problem? and if so how did you fix it?
Thanks in advance for the help,
Cajun
Old Oct 18, 2003 | 11:12 AM
builtfspd2's Avatar
builtfspd2
Default Re: belt squel? (ccajun4real)
i had similiar problem, changed both belts and squeal went away. it might be coming back. some peeps have bought gatorback belts. i believe mine is the pulley on the a/c compressor. not sure if this helps.......
Old Oct 19, 2003 | 02:55 AM
VFRLuke's Avatar
VFRLuke
I had a problem with mine squeaking at idle mostly. I took both belts off and turned everything feeling for what might have been a bad bearing or something of the sort. I couldn't find anything so I replaced both belts with gatorback's and it's been quiet since then.
I'd try this first.
Luke
Old Oct 19, 2003 | 12:26 PM
builtfspd2's Avatar
builtfspd2
Default Re: belt squel? (VFRLuke)
how much are gatorbacks compared to stock? can you get them anywhere or only at dealer?
Old Oct 19, 2003 | 11:00 PM
VFRLuke's Avatar
VFRLuke
Default Re: belt squel? (builtfspd2)
I got mine at autozone. I can't remember exactly what the price was.
Luke
Old Oct 20, 2003 | 12:37 PM
builtfspd2's Avatar
builtfspd2
well my squeal is back after installing 2 new belts and driving for a small bit. i guess gatorbacks i will have to try. :mad
Old Oct 21, 2003 | 01:00 AM
Jimmy 2 Times's Avatar
Jimmy 2 Times
buy new belts, and a can of brake kleen........ spray the pullies with the brake kleen, let it dry, then put on the new belts. worked for me after i did my pully swap (went through 3 belts I did this)
jimmy
Old Oct 21, 2003 | 07:58 AM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
$27 compared to the GM Dayco at $55. The gatorback is the way to go. I purchases 2 dayco belts and all new pulleys trying to get rid of a squeek and after I put a Goodyear gatorback on the squeek was gone. Nuff said.
You have to order it from Autozone. They will probably say they can't get it but keep on them. You need to find someone that knows what they are doing behind the counter. Someone said on the forum that you have to get them to look it up for a 97-98 model????
Old Oct 21, 2003 | 08:16 AM
builtfspd2's Avatar
builtfspd2
Default Re: belt squel? (C5-VERT)
i will try that :) whats the difference in belts? why doesnt the gators squeal also? just curious? :confused:
[Modified by builtfspd2, 8:40 AM 10/21/2003]
Old Oct 21, 2003 | 09:33 AM
C5-VERT's Avatar
C5-VERT
The grooves look entirely different. You will see when you compare. The composed material may be different also.
Old Oct 22, 2003 | 09:35 AM
builtfspd2's Avatar
builtfspd2
got the gator belt, a/c small one. picking up other serpentine (98) model belt tomorrow. got my brake kleen. hopefully it works. other belts lasted 500 miles and started squeaking. :(
Old Oct 22, 2003 | 02:39 PM
0Cajun @ Edgyvette
Former Vendor
Ordered the main drive/alternator belt today at Autozone ($24.66+tax) the part number is 4060798 :flag
Old Oct 22, 2003 | 03:05 PM
vectorz's Avatar
vectorz
I've had belt squeal, and used break clean on them to quiet them, only to find out later that it was my water pump and|or a/c compressor going out. The pulley wheel on these items were ceasing up slowly over time, causing the belts to drag and not grip. Just something to watch out for.
Old Oct 26, 2003 | 08:41 AM
0Cajun @ Edgyvette
Former Vendor
Default Re: belt squel? (vectorz)
I switched to the gatorback main drive belt and the belt is still squealing like hell :mad I swear it seems like it could be my tensioner pulley. :confused: This is going to be a long and drawn out deal I think. Autozone carries a smaller, narrower belt that they list for vettes with AC. I can not find where this belt would go?? The car only uses one belt right? I did not spray with brake clean so I will try that.
Also wanted to know if anyone knows what the tick marks on the top of the idler pulley means? Is there a way to adjust the tensioner? Thanks
Old Oct 26, 2003 | 08:47 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
The last time my belt made noise it turned out to be the water pump.... :smash:
VR :cheers:
Old Oct 26, 2003 | 01:18 PM
builtfspd2's Avatar
builtfspd2
i have a 2000 and takes 2 belts. one big serpentine belt and the a/c belt. changed both and currently my squeal is gone. will keep an eye on the tension for the a/c as thats manual.
Old Oct 26, 2003 | 01:39 PM
0Cajun @ Edgyvette
Former Vendor
I have a 2000 also and only have one belt. Where does the other one go :confused: Man I may have a serious problem here. Do you have to get under the car to see the AC belt? Please let me know ASAP, Thanks
To belt squel?
Old Oct 26, 2003 | 02:04 PM
builtfspd2's Avatar
builtfspd2
http://[ <a href="http://www.geociti...pd2/tires</a>]
[Modified by builtfspd2, 2:07 PM 10/26/2003]
Old Oct 26, 2003 | 02:08 PM
builtfspd2's Avatar
builtfspd2
i know the pic isnt big, if you have your manual, its in their too.
Old Oct 26, 2003 | 03:34 PM
0Cajun @ Edgyvette
Former Vendor
I do not have the manual, bought it used and it didnt have one. I need to get one. Thank you very much for sending me the pic. I am going to look for that belt now. Do you have to look from under the car to see it? Thanks again
Cajun
