MSD Wires Problem
Old Oct 18, 2003 | 11:39 AM
Net Exploit's Avatar
Net Exploit
Default MSD Wires Problem
Hi All,
Yesterday my C5 starting running like do do. I just the plugs and wires to NGK T55 Iridiums and MSD wires. The plugs and wires have been on for about 3 months. So, my first instinct was to check the plugs and wires for good connections.
They all seemed OK, so I took the car for another test drive, same thing.
So, upon closer inspection, I noticed that the number 7 wire was sitting directly on the header. I pulled the wire off and the insulation was burnt. I replaced that wire with one of the old GM wires, and took it out for another run.
Problem fixed. Do any of you know how to get that wire from resting on the header. I will order a replacement MSD wire, but I will need to come up with something, so that wire does not rest on the header.
Glad to have the C5 back running good.
Any suggestions?
:crazy:
:D
Old Oct 18, 2003 | 12:16 PM
CapeCodCoupe's Avatar
CapeCodCoupe
Default Re: MSD Wires Problem (Net Exploit)
I have not had that problem but I remember there were postings concerning this. Someone said you can special order a wire from MSD that will provide the needed clearance. Search the archives?
Old Oct 18, 2003 | 12:19 PM
Net Exploit
Default Re: MSD Wires Problem (CapeCodCoupe)
Thank You, I will do that.
Cheers..... :cheers:
Old Oct 19, 2003 | 05:05 PM
carpe dm's Avatar
carpe dm
Jegs, hot rod shops, etc. sell a product called "cool sox" that are insulating covers for plug wires. They work great, but you still need to find a way to keep them from actually touching the header tubes. :yesnod: :)
To MSD Wires Problem
