Adjustable Fuel Pressure Regulator
Old Oct 18, 2003 | 05:04 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Default Adjustable Fuel Pressure Regulator
Has anyone used this Adjustable Fuel Pressure Regulator on your 97/98?
How do you adjust it?
http://www.madvet.com/shop?store=2&category=13&frame=19
:cheers:
Old Oct 18, 2003 | 05:18 PM
Red C5's Avatar
Red C5
Default Re: Adjustable Fuel Pressure Regulator (mike76002)
Why is it only for 97-98?
Old Oct 18, 2003 | 05:26 PM
0Vette Stripes
Former Vendor
Default Re: Adjustable Fuel Pressure Regulator (Red C5)
I beleive 99 and newer got one.
I have read it from the Corvette Magazine but could not find that info.
I only find this link from them ...
http://www.corvettemagazine.com/2003.../np1-1-3rd.asp
Old Oct 18, 2003 | 05:45 PM
racetchr's Avatar
racetchr
97 and 98 had a different fuel system. This configuration had 2 fuel lines to the fuel rail, one a delivery and one was a return line. It allowed for the pressure to be regulated at the fuel rail, ie., regulator. It is adjusted by an adjustment screw on the housing. You would need to attach a fuel pressure gauge to get a correct adjustment.
Old Oct 18, 2003 | 06:04 PM
CapeCodCoupe's Avatar
CapeCodCoupe
Default Re: Adjustable Fuel Pressure Regulator (racetchr)
Does anyone have instructions on installation and configuration? I bought one a year ago and never installed it.
Old Oct 18, 2003 | 06:37 PM
0Vette Stripes
Former Vendor
Default Re: Adjustable Fuel Pressure Regulator (CapeCodCoupe)
So it does not have instruction when you bought it new?
I thought it is adjust fuel pressure automatically
Old Oct 18, 2003 | 09:08 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have the instructions somewhere and I will go look for them. If you add this to your car you will need some way to monitor all of the functions that it effects. You need to know where your LTFT and STFT are already. If your car if running real rich or lean the regulator adjustment will be able to help. If you already have good fuel trims and crank in more or less fuel pressure you could hurt your performance. That is why I never installed mine. I am going to wait until I purchase LS1 edit.
BC
Bill C
Old Oct 18, 2003 | 09:10 PM
geekracer's Avatar
geekracer
I have an AFPR on my '98. Mine has a bolt that you turn to adjust the pressure. You need the fuel pressure guage to know what the pressure is set to. Set it with the BARO line disconnected.
Old Oct 18, 2003 | 09:54 PM
CapeCodCoupe
Default Re: Adjustable Fuel Pressure Regulator (MMarquez)
Yes it does come with instructions but they are vague to say the least. The bottom line in the instructions says: "Tip: Set to 54-55 psi." Can anyone agree this is the right pressure for my set up?
Old Oct 18, 2003 | 10:17 PM
0Vette Stripes
Former Vendor
Default Re: Adjustable Fuel Pressure Regulator (Bill Curlee)
BC
Bill C
So if I got LS1 edit, I don't need this Adjustable Fuel Pressure Regulator, do I?
Old Oct 18, 2003 | 10:23 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well,,,, that may not be totally true. If your Fuel Pressure is high or low the adjustable regulator can fix it, The regulator is just another method of changing the way you engine runs. Use the LS1 edit to see what your engine is doing and what it needs to do it better!!! :thumbs:
Bill C
Old Oct 19, 2003 | 12:50 AM
TopCat's Avatar
TopCat
This is what I found out; choose the path you like, just suggestions. The 97/98s, as I've learned, run rich, period. Especially at WOT. You can lean them out some with intake (Blackwing) and cat-backs. Perfect fuel ratio is @ 14.7:1 (stoichiometric ratio). Max. power is achieved at @ 13:1. You can get an AFPR for @ $120 plus an MAFT (@$100+) for a temporary fix (the PCM learns out the MAFT except for the WOT fuel tables), or get a mail-order LS1 Edit (@$250), or purchase AutoTap and LS1 Edit to make the changes yourself.
If you choose the AFPR, I've heard that 51 psig is the setting to shoot for. However, lowering your fuel pressure will impact the injector spray pattern, i.e. less efficient air/fuel mixture in the combustion chamber. For now, I've chosen the mail order route since I can have the PCM updated free (plus shipping) for the next 60 days, and $50 thereafter. I WILL purchase LS1 Edit in the future to fine tune myself, but as a quick fix to the run-rich problem (plus adjusting the fan 'turn-on' temps, tranny shift points, etc, etc, etc) I felt that having the mail-order tune was the best route.....and I'm very happy with my decision :D :D :D :D :D
Old Oct 19, 2003 | 02:32 AM
0Vette Stripes
Former Vendor
Default Re: Adjustable Fuel Pressure Regulator (TopCat)
Well, I got LS1 edited by LG and re-tune will cost 150$ if I put in on a dyno.
I am about to have it re-tuned so I think they will adjust fuel pressor.
I know my car is running rich now because at idle, I can smell all the gasoline even with cats.
Anh why with cat-backs can lean out a bit?
To Adjustable Fuel Pressure Regulator
