Which LT Headers are better?
I am very pleased with the results.
Our center section is 3" from the headers all the way back. We also are the only manufacturer that backs our products with a limited lifetime warranty.
It is subjective for one header manufacturer to say that their header will or won't make more power-every car is different, every tune is different, etc. Making claims that a header makes more power is not easily supported-unless you compare the same car, EXACT same tune, and honestly, have an independent dyno shop test them. We do not bash other products or make claims that they make more power than other companies.
Our headers are used by more tuner shops-LS1 speed, LS1MS, Agostino, Extreme, Corvette garage, Performance Technical center, wheel to wheel, mallett, than any other header (actually, I can't verify this claim because I do not know who company ABC sells to). The point is, if there was a better product, companies that stake their reputation on making the most power would sell it and not sell ours. and last time I check Lingenfelters still sells their "mid length" headers, which they have built for them. Strange they do this and still make killer power and have arguably the best rep on the web for their packages.
I do know that our headers and exhaust were just used on the MTI built Z07 of Ron Adee that won the one lap, and our exhaust is on what is claimed to be the fastest N/A C5 of John Lawson (engine built by Cartek, he uses their headers, which are "mid length" as some call them with our 3" exhaust)
What is the time requirement to install these LT and do they install from the bottom or top?
Any problems at all from the pcm? No codes, etc?? Can you tack weld a CARB# on them if I find a plate? :D
LG Pro Long Tube headers available at :
LS1-Speed ( speed inc)
A and A Corvettes (Andy)
Corvettes of Houston
West Coast Corvettes
More Performance in NC
Leighton's Garage in Mpls.
Xtreme Motorsports
Corvette Garage
ACP Harrisburg,PA
LM Performance
With our LG Pro Long Tubes, we pick up the torque in the low and mid range.
There are some systems that get good "Peak" numbers, but lack in the low and mid range where most Corvette owners drive 99% of the time.
So our design does deliver the good high end numbers, as shown in our Cam and Head packages, but at the same time they deliver the Torque to pull out of a slow corner.
We just sent out another header to a new Speed World Challenge racer for a new car being built for the 2004 season. He said that he needed "Grunt" out of the corners, and the LG headers will do the job.
Thanks guys, Whatever header you choose, you will be much happier than without headers.
LG
Which LT header is better?
TPIS, LG, Stainless LT or FLP?
Thanx for input.
Do the headers come apart like others.
Just need some info.
And are the LG headers stainless and coated ceramic for temp.
Thanx
