go to pep boys and get a bottle of G2P, or guaranteed to pass, it is an additive to help reduce the CO and HC read outs, and they will guarantee you to pass or money back plus emissions costs or something. I think you have to dump it in a full tank of gas, then take it to get inspected. by the way, try running your car for about a half hour before you get put on the sniffer, your car will run cleaner when it is warmed up
btw, that is a bad butt engine :yesnod: , what is LSA on your cam?
:iagree: Also, you can loosen the manifold bolts a little so there is a small leak that is barely noticeable to the ear. I've had to do both of these to get my camaro to pass.
HOLY COW! My carburated ZZ3 engine in my 68 put out only 70 ppm of HC. You are in the gross polluter territory! I'll bet your air/fuel ratio is way off. I'd take it to a tuner who can measure HCs and get them down where they belong.
