Is it a normal cold engine noise?
I might be obsessing too much over it but I'm concern about this slapping/knocking sound that is present for a short moment when the engine is cranking, but b/f it it fired up. This noise disappears as soon as the engine fires up. This knocking sound is pretty intrussive - it is best heard on the second start.
The car is 03 Z06 with <5K miles on it. Oil has been changed less than 1000 miles ago and at normal level
It is only present when the abmbient temperature is cool (<60).
Here is how it sounds at ambient temp of 85 degrees.
Engine at 85 degrees
Engine at 55 degrees
Pay close attention to the second start during cold weather - that is when the knocking is most noticeable
[Modified by PeterK, 1:08 PM 10/22/2003]
you can hear mine from quiet a distance.
I will know more about it mnday when i get a diagnosis from David at TJC.
People have already asked me if the car is alright because it sound kind of strange.
[Modified by PeterK, 1:34 PM 10/22/2003]
Do you think my battery can be weak?
Hmm,
Since the 2nd cold start sounded slower (almost didn't start sounding), checking for a weak/bad battery, dirty post contacts, alternator, etc., is a good first guess. The starter solenoid contacts could also be dirty.
A potential source of the noise is the starter solenoid being actuated by the key wiring path, which sends current to the electromagnet in the starter. This pulls the solenoid to engage high amp contacts to run the starter motor. With a weak battery system, the loss of current to run the starter motor causes the electromagnet to lose power, and spring back, cutting the starter motor. Once this happens, there is now enough electromagnet power to re-engage the starter contacts. This cycle occurs rapidly, making noise.
Otherwise, your engine sounds great, nice and smooth and quiet.
Nice job on the recordings! Very professional! :thumbs:
I would have to agree that it sounds like a solonid or internal starter problem. Could be a bendix that is weak ot excessively loose.
So,,, the service guy says it normal! :rolleyes: :skep:
If I were you I would ask the dealer to crank up one of his new Vetts on the lot and see if it makes the same noise. I dont think he will want to compare them.
Honestly, I would tell him that you think it is an abnormal noise and ask him to replace the starter. If he wont, ask to speak to the service manager about it. If he wont play ask to speak to the Distric Service Rep.
He(( its only a starter! It's not like your asking for a new engine or drive train! :D
Bill C
[Modified by dubya, 5:27 PM 10/22/2003]
So since it is not engine related - I'm gonna wait until the situation becomes worse. I presume that I'm not under any major risk?
I would take it in and make your complaint known! Get it on paper as to the severity of the problem when it ocurrs and what causes it.
If it get worse you have documented evidence of that and it will make a better case for replacement.
The noise is not normal and very distinct! If they say it normal take it to another dealer and get a second opinion.
Please keep us informed on how it turns out
Good luck!
Bill C
Pete, I wouldn't wait. Bring those audio clips into the dealer and request a starter change-out under warranty. This would not take the dealer long to do and would give some piece of mind to all parties involved. At the least I would get something signed from the dealer stating they have heard your concerns. And Then I would find a new dealer. Even if you have to drive several hundred miles. Then I would write a certified letter to GM stating your concerns about the certified GM dealer. Just my .02. Hope this helps.
Find a new dealer. Good luck on this one.
So I'm kind of SOL here, I guess I'll have to wait until it breaks down.
