99 vette tranny issue
Old Oct 22, 2003 | 08:16 PM
99VETTETOOFAST's Avatar
99VETTETOOFAST
Default 99 vette tranny issue
Its an auto tranny , im having problems with the car shuddering a bit between 3 and OD. When i punch the gas it will shift up no probleme. When i gently throttle it , the car will pause and jump back and forth a bit trying to get into gear. Im not sure whether this sounds like torque converter or tranny. And the car mostly does it when it shift down from OD then i give it light gas and the probleme occurs. Seems like it might be down shifting a little soon. Any help would be great. thanks.
Old Oct 22, 2003 | 11:09 PM
1SGRET's Avatar
1SGRET
St. Jude Donor '12-'13
Default Re: 99 vette tranny issue (99VETTETOOFAST)
:lurk:
Old Oct 23, 2003 | 10:08 AM
tabbruzz's Avatar
tabbruzz
Do you have any mods or is it stock???
Old Oct 23, 2003 | 10:16 AM
carpe dm's Avatar
carpe dm
Welcome to the Forum! I hope someone checks to see if there is a TSB on this. I have a complete list, but am on the road at the moment. It sounds to me like mechanical/switch problem. Good luck.
Old Oct 23, 2003 | 11:24 AM
99VETTETOOFAST
yes the car is stock, what is this TSB you are talking about
Old Oct 23, 2003 | 01:01 PM
jawski's Avatar
jawski
first, check your fluid level.
Old Oct 23, 2003 | 02:33 PM
FO SHIZZLE's Avatar
FO SHIZZLE
A TSB is a GM service bulletin.
Old Oct 23, 2003 | 05:49 PM
99VETTETOOFAST
i checked the fluid level and replaced it.
Old Oct 23, 2003 | 11:51 PM
99VETTETOOFAST
ok it seem like the car is shifting down to 3rd too late , and shifting up into OD too early. It kinda feels like a standard would if you went into too high of a gear for your speed that bogging out it gets. What would cause the car to do this? would that hypertec module help this by changing the shift? Anyone have any ideas , any help would be great. It only does it when i give it light gas , at wide open throttle it is fine.
To 99 vette tranny issue
