Cable or throttle by wire on 2001?
Old Oct 23, 2003 | 06:30 PM
Shortimer's Avatar
Shortimer
Default Cable or throttle by wire on 2001?
I was under the hood of my 2001 today and could not find anything that looked link throttle linkage. Does the 2001 use throttle by wire?
I was trying to trouble shoot the cruise control. It doesn't work. I've already checked the fuse, it's fine, checked the rear brake lights, all are working, and checked the brake peddle to make sure it was all the way up. No luck. Guess I'll have to take it to the Chevy dealer while it's still under warranty. I was hoping it would be something simple like a loose connection or linkage that came undone. :-(
Old Oct 23, 2003 | 06:43 PM
jmX's Avatar
jmX
Default Re: Cable or throttle by wire on 2001? (Shortimer)
All C5's are throttle by wire.
Old Oct 23, 2003 | 07:38 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: Cable or throttle by wire on 2001? (jmX)
Check the DIC for any codes. It may lead you to the fault. If no codes are set, I would have the dealer look at it.
BC
Old Oct 23, 2003 | 08:25 PM
Shortimer's Avatar
Shortimer
Default Re: Cable or throttle by wire on 2001? (Bill Curlee)
Thanks for the feedback. Makes sense that it's throttle by wire but I'm new (one week) to C5s. I'm learning!
Old Oct 24, 2003 | 12:05 PM
All the C5's have throttle by wire. :yesnod:
Old Oct 24, 2003 | 09:52 PM
rhoeven's Avatar
rhoeven
If you have a 6-speed, check the switch at the clutxh pedal.
Roger
Old Oct 24, 2003 | 09:58 PM
Shylor's Avatar
Shylor
I'm not trying to be rude but, the best thing to do is learn about the car before you buy. That goes for any type of car you purchase. That way you will know if the dealership or person you buy from is giving you bull. With use of the Internet we all should be informed buyers and never over pay or be fooled.
Old Oct 24, 2003 | 10:07 PM
Shortimer's Avatar
Shortimer
Default Re: Cable or throttle by wire on 2001? (Shylor)
Appreciate all the input and no offense was taken. Car is going to the dealer on Saturday. It will be fixed under warranty. From my time on the forum, both the C4 and now the C5 forums, it's clear our cars give us headaches from time-to-time. We can only hope the problems occur while it's still under warranty as is the case with my '01.
To Cable or throttle by wire on 2001?
