What triggeres "low coolant"
Oct 24, 2003 | 01:16 PM
my coolant is not low but I've seen this a couple of times?
Oct 24, 2003 | 01:25 PM
Re: What triggeres "low coolant" (tblazec5)
Sometimes if you are parked on a slight incline. Mine has done this a couple of times start driving and it is fine :seeya
Oct 24, 2003 | 01:46 PM
It's a faulty sensor on the windshild washer tank - it's a notorius problem with C5s according to my dealership :yesnod:
:seeya
Oct 24, 2003 | 02:04 PM
Re: What triggeres "low coolant" (SeaFive)
What does the windshield washer tank have to do with engine coolant?
Bill
Oct 24, 2003 | 02:38 PM
Re: What triggeres "low coolant" (C5inNY)
It's my understanding that the sensor is on the coolant reservoir.
Oct 24, 2003 | 02:57 PM
St. Jude Donor '03-'04
Bill
OMG.... the guy makes a little mistake and you are all over him like hair on a Gorilla... :blueangel:
Oct 24, 2003 | 02:59 PM
Mine does this everytime I parked on even the slightest incline. Even a steep driveway triggers mine.
Oct 24, 2003 | 08:42 PM
I've had the same problem. Adding just a little more coolant will make it go away. :flag
Oct 28, 2003 | 09:45 PM
Definately the inclined parking. Just make sure its the incline and not a real low coolant message. :D
Oct 28, 2003 | 10:31 PM
Probably getting a bad sensor...mine had started some intermittent probs, I understand the new owner got it fixed...
Oct 28, 2003 | 11:15 PM
Could be that the car is not parked level and the sensor is reading a low level. Sensor is on the coolant tank.
Oct 29, 2003 | 08:08 AM
tblazec5,
This TSB applies to 1997 - 1999 C5's:
http://corvetteactioncenter.com/kb/q....php?qstId=259
I had the same problem and I followed the instructions on the TSB and added a little coolant to the overflow bottle. That eliminated the DIC messages. Good luck.
