Tire Leak
Old Oct 26, 2003 | 05:36 AM
vectorz's Avatar
vectorz
Default Tire Leak
I have a tire leak on my chrome wagon wheel. When the tire was pulled off in attempt to fix, we found some of the chrome flaking off. The tire guy said that was the cause of the leak and the rim has to be re-chromed in order to solve the problem. Anyone know if this is true, and what to look out for when I look for a chroming shop? Any recommendations for Los Angeles area?
Old Oct 26, 2003 | 07:29 AM
AFVETTE's Avatar
AFVETTE
Default Re: Tire Leak (vectorz)
Flaking chrome isn't going to cause a tire to leak air. I'd suggest you mix up some soapy water and use a paint brush to apply all around the rim and the valve stem. I think it's the valve stem area. Especially if the sensors were touched. It either needs to be tightened or the O-ring is bad.
If the wheel isn't damaged there should be no leaks around the rim/tire bead.
Good luck
Tom
Old Oct 26, 2003 | 08:22 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: Tire Leak (AFVETTE)
Good luck
Tom
:iagree: kinda what I was thinking
Old Oct 26, 2003 | 11:25 AM
vectorz's Avatar
vectorz
Cool, thanks for the advice. Will check it out.
Old Oct 26, 2003 | 01:34 PM
carpe dm's Avatar
carpe dm
If your wheels are so porus that the only thing holding the air in is the chrome, you need some new wheels! If you have pressure sensors, make sure they are installed correctly and are on tight. The bead of the tire may not be seating properly either. Could be several things. :yesnod: :)
Old Oct 26, 2003 | 04:11 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
Default Re: Tire Leak (carpe dm)
Had a slow leak, one pound a week, in my right rear tire. Checked the tire pressure sensor nut, and it was hand tight, supposed to be torqued to seven newton meters. This cured the problem.
Flaking chrome is not going to be the fault of your air leak.
To Tire Leak
