Keychain door unlockers don't work
Old Oct 27, 2003 | 06:59 PM
eddieerb's Avatar
eddieerb
Default Keychain door unlockers don't work
I changed the battery twice in both units- still not working. could it be on the cars end?
Old Oct 27, 2003 | 07:03 PM
tomdcarguy's Avatar
tomdcarguy
From: A.M.R. Pound for Pound-Fastest Stock Bottom LS1 9.1x 10psi
Default Re: Keychain door unlockers don't work (eddieerb)
..go under FOB training and reprogram the remotes.. should work
Old Oct 27, 2003 | 07:17 PM
wwashing's Avatar
wwashing
Stand next to the car and press UNLOCK and LOCK at the same time and wait a few for the horn to sound. You should be good to go! :cheers:
Old Oct 27, 2003 | 07:38 PM
eddieerb's Avatar
eddieerb
This worked with one unit but not the other :confused:
Old Oct 27, 2003 | 07:55 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Look in the owners manual under FOB training & FOB learning! Do the relearn procedure. You can learn up to 3 FOBs. Once you do the re-learn, if your FOB's dont work you can try to SYNC them by pressing LOCK & UN-LOCK at the same time and holding it until the horn beeps!
This should do you right! :thumbs:
BC
Old Oct 27, 2003 | 08:34 PM
eddieerb's Avatar
eddieerb
Thanks guys,
corvette forum has again saved my money from the local GM service dept.
Old Oct 28, 2003 | 09:24 PM
BlackC5Vette's Avatar
BlackC5Vette
A search on Fob training should yield a few helpful treads, you probably just need to reprogram them. ;)
Old Oct 28, 2003 | 10:33 PM
PaceThis's Avatar
PaceThis
reprogram them...if they don't take and you have new batteries...they're junk.
To Keychain door unlockers don't work
